containrrr/Watchtower and credentials
patricepm
Getting the hang of things
Post by patricepm »
Hi all,
I've managed to setup containrrr/watchtower. So far that it is trying to check if updates of my containers are available.
During the whole trail and error phase I also had to delete the directory config.json and create a new config.json file.
Formerly I used the v2Tec/watchtower image and worked with out problems (so why change the image....just because it hasn't been updated anymore for about 3 years).
Now, I have the containrrr/watchtower installed but it doesn't update because it is asking for credentials.... No idea what kind of credentials from what or where, I've never created an account to login and get images..
Does someone had a same experience and if so, how was it solved?
Thanks in advance for the help.
QNAP TVS-473
- 4x WD Red Pro 6TB (RAID 10)
- 2x WD SA510 1TB (RAID 1)
- 2x Samsung 970 Evo plus m.2 1TB (RAID 1)
- 40GB Memory
- Firmware: QTS 5.1.1.2491
jeffski10
Re: containrrr/Watchtower and credentials
Post by jeffski10 »
I'm running the containrrr one and its been fine for me. When you say update - do you mean update itself or it won't actually update any other docker images?
Return to “Container Station”
