I have a container which is stuck in Container Station.
The Application is Home Assistant official container version 2021.6.6
After stopping the application using the graceful "Stop" command in the App itself (which I have done hundred of times before), CS still list the container as running, and attempts to stop the container from CS just result in a never-ending spinning wheel. Console Terminal cannot be opened, of course, because the container isn't really running. Restart or remove commands also just end up in never-ending spinning wheel.
Attempt to create a new container from the same image fails with the following error:
Background task error for create HA-21.6.6-n: UnixHTTPConnectionPool(host='localhost', port=None): Read timed out. (read timeout=90)
Attempt to stop container station failed (never ending)
Attempt to reboot the NAS failed (never end)
