container-station/python2.7 docker-monitor.pyc High CPU Load
blue_focus
First post
Post by blue_focus »
Hi there,
Does any one know what this compiled python script (part of Container-Station) exactly does?
I observed quite much CPU-Time on my QNAP TS-853A
top - 07:04:32 up 6 days, 16:14,  0 users,  load average: 4.04, 3.80, 3.27
Tasks: 811 total,   2 running, 808 sleeping,   0 stopped,   1 zombie
%Cpu(s):  8.0 us,  6.0 sy,  0.0 ni, 85.8 id,  0.1 wa,  0.0 hi,  0.1 si,  0.0 st
MiB Mem :  15925.6 total,    337.9 free,   5941.3 used,   9646.4 buff/cache
MiB Swap:  15672.8 total,  14699.1 free,    973.7 used.   9855.9 avail Mem
  PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
11170 root      20   0  220356  49848   8132 S   7.8   0.3 783:11.60 container-station/python2.7 docker-monitor.pyc
27614 root      20   0   10.1g   1.3g  62580 S   7.8   8.5  60:58.35 influxd
 3452 root      20   0 2130884  13240   9176 S   5.8   0.1 629:42.86 /sbin/hal_daemon -f
 7947 root      20   0       0      0      0 S   3.2   0.0 635:05.96 [notify thread]
21310 root      20   0    8936   4220   2732 R   2.3   0.0   0:20.69 top
17384 1000      20   0  930628 111652   7704 S   1.9   0.7 183:31.52 /app/gitea/gitea web
18495 root      20   0       0      0      0 R   1.9   0.0   0:00.06 [pgrep]
10486 root      20   0  189980  35844  15184 S   1.3   0.2 122:47.85 /mnt/ext/opt/Python/bin/python /mnt/ext/opt/netmgr/api/core/asd.pyc
12086 root      20   0   50588  14392   2904 S   1.3   0.1 113:35.20 /share/CACHEDEV10_DATA/.qpkg/PlexMediaServer/Plex DLNA Server
13083 root      20   0 1446640 303912   1936 S   1.3   1.9 134:46.31 /opt/mssql/bin/sqlservr
 6272 root      20   0 2581912  83584   8528 S   1.0   0.5 102:45.85 /QVS/usr/bin/python -u -m /QVS/qvs/qvs/daemon_manager
 7587 root      20   0 2558048  71928  10716 S   1.0   0.4 187:01.67 container-station/dockerd -H tcp://0.0.0.0:2376 -H unix:///var/run/docker.sock --bridge=lxcbr0 --tlsverify --tlscacert=/etc/docker/tls/ca.pem --tlscert=/etc/docker/tls/server+
 9101 65532     20   0 1470664  38220   9588 S   1.0   0.2  37:30.34 cloudflared --no-autoupdate tunnel
20313 root      20   0 1374368  96600      0 S   1.0   0.6  86:53.35 bin/mongod --dbpath /usr/lib/unifi/data/db --port 27117 --unixSocketPrefix /usr/lib/unifi/run --logRotate reopen --logappend --logpath /usr/lib/unifi/logs/mongod.log --pidfil+
22548 root      20   0  222600  32496   3572 S   1.0   0.2  38:33.55 python /share/CACHEDEV9_DATA/.qpkg/CloudDriveSync/bin/daemonmgr.pyc CGId start
 2993 root      20   0       0      0      0 I   0.6   0.0   0:02.34 [kworker/0:2]
10287 root      20   0 4723404 313008   7988 S   0.6   1.9  66:30.50 java -Dunifi.datadir=/unifi/data -Dunifi.logdir=/unifi/log
lblabr
Re: container-station/python2.7 docker-monitor.pyc High CPU Load
Post by lblabr »
i do have similar issues, but i need to have a closer look, it seems that conatiner station eats a lot of RAM, i just restarted my container station i will have a look into shell (top) in some days, after 14days used RAM increases abaut 5GB
Return to “Container Station”
