Linux Station Install failure
in 2021 still same isssue now rename ubuntu linux station fail at 60% cannot find archie.ubuntu.com and no idea how to devug.. perhaps should ssh to the box ..
- OneCD
Re: Linux Station Install failure
Hi All
So far I have not had success with installing the Linux Station on my h1288x.
So I have started to do some debugging
The /var/log/container-station/ubuntu-hd.log tells
[I 210818 20:03:21 distro.pyc:529] Install progress: 59
[I 210818 20:03:21 base_distro.pyc:181] read piece from cache: http://download.qnap.com/QPKG/linuxstat ... d64.txz.db
[I 210818 20:03:21 base_distro.pyc:205] merge
[I 210818 20:03:23 distro.pyc:188] downloading -> processing (progress=60, errmsg=None)
[I 210818 20:03:23 distro.pyc:263] {'state': 'processing', 'lxcname': 'ubuntu_2004', 'action': 'install', 'progress': 60, 'config': -1}
[I 210818 20:03:23 distro.pyc:529] Install progress: 60
[I 210818 20:03:23 distro.pyc:188] processing -> processing (progress=60, errmsg=None)
[I 210818 20:03:23 lxc.pyc:397] Enable
[I 210818 20:03:23 lxc.pyc:551] Set up network.1.link based on adapter1 config
[I 210818 20:03:23 lxc.pyc:145] use as interface [default]
[I 210818 20:03:23 lxc.pyc:213] use 'eth2' as interface [new default]
[W 210818 20:03:23 lxc.pyc:101] Failed load /share/ZFS530_DATA/.qpkg/ubuntu-hd/lxc/ubuntu_2004/lxc.network.link.physical.[[Errno 2] No such file or directory: '/share/ZFS530_DATA/.qpkg/ubuntu-hd/lxc/ubuntu_2004/lxc.network.link.physical']
[I 210818 20:03:23 lxc.pyc:559] change network interface to eth2 (bridge: br0)
[I 210818 20:03:23 lxc.pyc:594] Set up network.2.link based on adapter2 config
[I 210818 20:03:23 lxc.pyc:598] Use 'None' for network.2.link
[W 210818 20:03:23 lxc.pyc:47] Return False [cannot concatenate 'str' and 'NoneType' objects]
[W 210818 20:03:23 lxc.pyc:600] None is not worked. Set network.2.link to empty
[I 210818 20:03:25 lxc.pyc:426] Enable...running OK
[I 210818 20:03:25 lxc.pyc:439] Enable...echo OK
[I 210818 20:03:25 lxc.pyc:696] ['/share/ZFS530_DATA/.qpkg/container-station/bin/lxc-attach', '-P', '/share/ZFS530_DATA/.qpkg/ubuntu-hd/lxc', '-n', 'ubuntu_2004', '--', 'bash', '-c', 'ip a s eth0|grep "inet "']
[W 210818 20:03:25 lxc.pyc:710] `['/share/ZFS530_DATA/.qpkg/container-station/bin/lxc-attach', '-P', '/share/ZFS530_DATA/.qpkg/ubuntu-hd/lxc', '-n', 'ubuntu_2004', '--', 'bash', '-c', 'ip a s eth0|grep "inet "']` exited with 1 and output
[I 210818 20:03:26 lxc.pyc:696] ['/share/ZFS530_DATA/.qpkg/container-station/bin/lxc-attach', '-P', '/share/ZFS530_DATA/.qpkg/ubuntu-hd/lxc', '-n', 'ubuntu_2004', '--', 'bash', '-c', 'ip a s eth0|grep "inet "']
[W 210818 20:03:26 lxc.pyc:710] `['/share/ZFS530_DATA/.qpkg/container-station/bin/lxc-attach', '-P', '/share/ZFS530_DATA/.qpkg/ubuntu-hd/lxc', '-n', 'ubuntu_2004', '--', 'bash', '-c', 'ip a s eth0|grep "inet "']` exited with 1 and output
[I 210818 20:03:27 lxc.pyc:696] ['/share/ZFS530_DATA/.qpkg/container-station/bin/lxc-attach', '-P', '/share/ZFS530_DATA/.qpkg/ubuntu-hd/lxc', '-n', 'ubuntu_2004', '--', 'bash', '-c', 'ip a s eth0|grep "inet "']
[I 210818 20:03:27 lxc.pyc:699] inet 10.0.5.239/24 brd 10.0.5.255 scope global dynamic eth0
[I 210818 20:03:27 lxc.pyc:696] ['/share/ZFS530_DATA/.qpkg/container-station/bin/lxc-attach', '-P', '/share/ZFS530_DATA/.qpkg/ubuntu-hd/lxc', '-n', 'ubuntu_2004', '--', 'cat', '/etc/resolv.conf']
[I 210818 20:03:27 lxc.pyc:699] # This file is managed by man:systemd-resolved(8). Do not edit.
# This is a dynamic resolv.conf file for connecting local clients to the
# internal DNS stub resolver of systemd-resolved. This file lists all
# configured search domains.
# Run "resolvectl status" to see details about the uplink DNS servers
# currently in use.
# Third party programs must not access this file directly, but only through the
# symlink at /etc/resolv.conf. To manage man:resolv.conf(5) in a different way,
# replace this symlink by a static file or a different symlink.
# See man:systemd-resolved.service(8) for details about the supported modes of
# operation for /etc/resolv.conf.
nameserver 127.0.0.53
options edns0
[I 210818 20:03:27 lxc.pyc:696] ['/share/ZFS530_DATA/.qpkg/container-station/bin/lxc-attach', '-P', '/share/ZFS530_DATA/.qpkg/ubuntu-hd/lxc', '-n', 'ubuntu_2004', '--', 'ip', 'r']
[I 210818 20:03:27 lxc.pyc:699] default via 10.0.5.1 dev eth0.
10.0.5.0/24 dev eth0 proto kernel scope link src 10.0.5.239
The fun thing is that the file
do exist
The final error during install is "Could not connect to DNS server (127.0.0.53)"
Anyone have any ideas.
BR
Tim
# currently in use.
options edns0
do exist
BR
Tim
