I migrated from a ARM TS-231P to an Intel TS-253A by swapping the disks.
After opening Container station I found out, that I could not start any of the containers I had created on ARM.
when I create a new LXC on Intel, it works.
are containers not platform independent?
LXC of ARM not compatible with Intel?
Re: LXC of ARM not compatible with Intel?
Addition: I am finding "Unsupported LXC OS" errors in the CS-Log
There is absolutely no container station on the 11 year old 219p+ .. unclear how you would have started any containers on that device.
sorry! my typo. that 219 was my first qnap. its a 231P with an A15.
thank you for looking at this topic at all
try to pull the latest container version for your actual processor (x86/x64) (they normally pull the correct architecture on creation)
naja. I have fully configures containers for app development puroses.
if I set up a new container (LXD then), I need to setup the whole content again
