Hello. After upgrade to QuTS Hero h5.0.0.1772 my Container Station v2.4.0.2316 won't work. I see "Loading" message and nothing happens.
When I ssh to my NAS I see error message: Cannot connect to the Docker daemon at unix:///var/run/docker.sock. Is the docker daemon running?
The same error after CS reinstall.
Can anybody help me?
Container Station won't work after upgrade to QuTS Hero h5.0.0.1772
Re: Container Station won't work after upgrade to QuTS Hero h5.0.0.1772
report issues with the beta to qnap
@lexius - I confirm the same
Today I upgrade Container Station,it can't work, only show a blank window. QTS 4.5.4.1741
QNAP Support response:
The anomaly you have found results to be a known error to QNAP developers that will be corrected in the container station version 2.4.1.7.
TS-H886
Any chance QNAP support gave you an ETA on when version 2.4.1.7 will be released?
I can't believe QNAP made this beta 5 version a public release with a bug making container station unusable.
With today update now all working fine.
TS-H886
