NAS Model: TS-873A
Firmware: QuTS Hero h5.0.0.2069
Container Station: V2.6.0.483
Installed Container Station and when I try to run it I get an infinite loading with the the following error message:
Unable to access container-station-data folder
Failed to create new folder.
Anyone know what might be causing this problem? See attached screenshots for error messages.
Container Station Error - Unable to access container-station-data folder
Re: Container Station Error - Unable to access container-station-data folder
Do you have a system volume/pool+share (on QuTS) setup ?
Just the default setup:
Storage Pool 1 (System)
-Multimedia
-Public
-Recordings
-Multimedia
-Public
-Recordings
try to reinstall container station, I should see (setup) a container share
I have tried to reinstall it several times and it always tries to initialize setup to '/Container' (uneditable path). I then click on the I click 'Start Now >' button and Container Station then throws the same screenshotted error that I have posted at the start of this thread.
create a share with that name and try again
Thanks that fixed my issue. I wish the error message was a little more informative as to letting a user know that a share should be manually created if it doesn't already exist.
