I have attached a Seagate drive to the QNAS TS-212-E (rear USB socket) and the drive shows up on the 'Connected External Device' on the NAS home page icon. When I click on the icon it drops down and identifies the device correctly as 'USB1'. Clicking on that opens the File Station 5 Multimedia folder ... but there is no USB1 folder. Does anyone know why ? Naturally, I need to know what is being backed up, I need to visually see what's on the USB External drive.
Can anyone help?
gael.
[SOLVED] 2TB Seagate Expansion Desktop Drive SRD00F2
- gael33
Slàinte Mhath, Saor Alba Gu Brath.
Re: 2TB Seagate Expansion Desktop Drive SRD00F2
Have you checked the permissions to the USB drive?
(Home1) TS-410 ST31000340NS G005/ST1000NM0033 SN04 RAID 5 QTS 4.1.2 Build 20150126 APC Back-UPS NS 1250
(Home2) TS-120 ST1000NM0033 SN07 4.3.3.0378 Build 20171117 APC Back-UPS NS 1250
(Work1) TS-1270U 12-ST3000NM0033 RAID 6 QTS 4.1.0 APC Back-UPS NS 1250
(Work2) TS-459U 4-ST6000NM0024 RAID 5 APC Back-UPS NS 1250
(Work3) TS-439U 4-ST31000NM0033 SN04 RAID 5 QTS 4.1.2 Build 20141229
what is the file system on the drive ?
is it supported?
is it supported?
- gael33
Thanks for the advice guys. I clicked on the wee icon at the top of the opening screen and a menu came up asking what I wanted to do with the drive. Choosing the correct option opened the contents of the drive. So, all's well that ends well ... now to mark the topic as solved.
Thanks again.
gael
PS. The drive was formatted previously ... Ext4.
Thanks again.
gael
