WD Red 8tb 42C and 48C
Discuss and share your WD drive experience
beshur
Getting the hang of things
Contact:
Post by beshur »
Hello!
I have ts-253B and have recently installed the second drive. Both are WD Red 8Tb (WD80EFAX), but one is helium-filled (it has idle temp of 42C).
So without any serious load the drives are at 48C and 42C. This looks like a bit too hot.
Tried:
- swapping the drives in bays
- placed the NAS on top of the table (should be better ventilation)
No major effects to the drives' temperature.
Is it ok? What should I do?
Sent from my SM-G950F using Tapatalk
TS-253B-8G | 2x WD Red Plus 8Tb
dolbyman
Re: WD Red 8tb 42C and 48C
Post by dolbyman »
tried to raise the fan speed ?
beshur
Contact:
Post by beshur »
dolbyman wrote:tried to raise the fan speed ?
No, I haven't. It's already at 1600, but I'll try.
beshur
Contact:
Post by beshur »
I ran the fan at 100% for a couple of minutes, and the hot drive dropped 3 degrees.
Setting the fan mode to thresholds also not very viable - the lowest "hot" threshold is 45 degrees, which leads to the fan turning on and off every 20 seconds or so.
Is my situation unique?
holger_kuehn
Easy as a breeze
Post by holger_kuehn »
Just checked my NAS here are the values, but it might be a bit unfair as it's a (lot) roomier 16-bay NAS:
CPU: 37 °C / 98 °F
System: 29 °C / 84 °F
M2-SSD: 31°C / 87°F
SATA-SSD: 34 °C / 93 °F
HDD: 42 °C / 107 °F
CPU-Fan: 2580 RPM
3x System-Fans: 660 - 720 RPM
This is during heavy load, as a HDD-rebuild is running at the moment.
NAS (production): TS-1635AX FW: QTS 5.1.4.2596 build 20231128
NAS (backup): TS-1635AX FW: QTS 5.1.4.2596 build 20231128
Data (QTier): [RAID-6] 4 x 4TB Samsung 870 QVO Sata
Data (HDD): [RAID-6] 7 x 18TB Exos
RAM: 8 GB (QNAP shipped)
UPS: CyberPower CP900EPFCLCD
Usage: SMB with rclone (encrypted)
NAS: TS-873U-RP FW: QTS 5.1.4.2596 build 20231128
BACKUP: 4TB Synology DS214 FW: DSM 7.0.41890
Usage: SMB, Backup Domain Controller
rafale
Easy as a breeze
Post by rafale »
This seems indeed very hot:
I have 4 of these which run between 27-30C
Even my 4 WD purple 4GB which are constantly writing/recording videos from 16 cameras and should be fairly similar run between 34-36C. Granted my NAS is quite different. You probably have a ventilation problem.
Server: TVS-872XT i9 9900 ES, 64GB DDR4 2666MHz, intel X550-T2, Asus RTX3070 Dual OC (On pico PSU), 2x Phison E12 1TB M.2, 4x Micron 5210 7.68TB, 4x WD Purple 4TB
Backup NAS: TS-473 20GB DDR4 2400MHz, Mellanox ConnectX3, 2x Samsung PM871b 256GB M.2, 4x WD Red 8TB
Former units: TVS-1282, TS-871, TS-469
beshur
Contact:
Post by beshur »
How can I verify the ventilation problem?
The fan seems to work fine.
As I mentioned I tried putting it in more spacious location.
beshur
Contact:
Post by beshur »
Removed the front disk bay door, the temperature went down to 38/46 degrees (38 for Helium one).
Also tried playing with the fan modes, but not to much effect.
rafale
Easy as a breeze
Post by rafale »
Look for airflow blocking things as it appears to be your problem. Maybe even air circulation around the NAS itself.
beshur
Contact:
Post by beshur »
rafale wrote:Look for airflow blocking things as it appears to be your problem. Maybe even air circulation around the NAS itself.
Thank you for the suggestion.
I have moved the NAS up on a table, and even tried laying it on its side (since the largest exhaust port that leads to the reactor core ;)) is on its bottom. No change in temperature though.
beshur
Contact:
Post by beshur »
Got some more advices from QNAP support and a tool to check background jobs that prevent disks going to standby (but haven't gone through the points just yet).
In the meantime I changed the standby inactivity time to 5 minutes (from 30 minutes) - and it helped a lot - I can hear the disks spinning down and up when I'm around, and the temperatures went down to 33C and 39C respectively.
rafale
Easy as a breeze
Post by rafale »
This is pretty strange. I just moved my 4 disk array to another QNAP NAS (473) and the temperatures remain in the low 30s and without having to put my drive in standby as they are constantly recording backups from my various MacOS devices.
beshur
Contact:
Post by beshur »
Apparently the last thing keeping the drives from sleeping was the Qsync.
I believe it polls NAS periodically, not allowing the disks to effectively cool down.
I don't really use it much, so I paused sync, and start it up on the rare occasions I need to sync stuff.
Also I scheduled the Mac TimeMachine backups to only happen once a day, close to midnight.
Now my temperatures in standby are around 28-30 (Helium), 32-34 (non-Helium).
Return to “Western Digital Drive Discussion”
