hi i have 2 hdd wd nas 3tb efrx that come from a synology nas, one of them works fine but the other one is locked with an ATA password. I have tried to unblock it by ssh with the hdparm command but I think the version that qnap brings to hdparm is very old, is there a way to update hdparm or can it be unlocked in another way?
P.S. I don't have any other computer to connect the disk.
Hdd wd nas 3tb EFRX LOCKED
- OneCD
Re: Hdd wd nas 3tb EFRX LOCKED
I've just checked and both QTS 4.2.6 and QTS 4.5.1 include version 6.1 of 'hdparm' which has the required options (specifically '--security-unlock'):Diejeitor wrote: ↑Sat Jan 16, 2021 11:38 pm hi i have 2 hdd wd nas 3tb efrx that come from a synology nas, one of them works fine but the other one is locked with an ATA password. I have tried to unblock it by ssh with the hdparm command but I think the version that qnap brings to hdparm is very old, is there a way to update hdparm or can it be unlocked in another way?
ATA Security Options:
--security-freeze Freeze security settings (until next reset)
--security-unlock PWD Unlock drive, using password PWD (DANGEROUS)
--security-set-pass PWD Lock drive, using password PWD (DANGEROUS)
--security-disable PWD Disable drive locking, using password PWD (DANGEROUS)
--security-mode MODE Specify user/master password and high/maximum security
u user password, high security
U user password, maximum security
m master password, high security
M master password, maximum security
OneCD wrote: ↑Sun Jan 17, 2021 3:59 amI've just checked and both QTS 4.2.6 and QTS 4.5.1 include version 6.1 of 'hdparm' which has the required options (specifically '--security-unlock'):Diejeitor wrote: ↑Sat Jan 16, 2021 11:38 pm hi i have 2 hdd wd nas 3tb efrx that come from a synology nas, one of them works fine but the other one is locked with an ATA password. I have tried to unblock it by ssh with the hdparm command but I think the version that qnap brings to hdparm is very old, is there a way to update hdparm or can it be unlocked in another way?What is the model of your NAS? What firmware and build number is installed? What happens when you try to unlock the drive?Code: Select all
ATA Security Options: --security-freeze Freeze security settings (until next reset) --security-unlock PWD Unlock drive, using password PWD (DANGEROUS) --security-set-pass PWD Lock drive, using password PWD (DANGEROUS) --security-disable PWD Disable drive locking, using password PWD (DANGEROUS) --security-mode MODE Specify user/master password and high/maximum security u user password, high security U user password, maximum security m master password, high security M master password, maximum security
I have already seen that and indeed the problem is not there, the disk is locked by ATA password, we have managed to unlock it by connecting it to a desktop pc through Ubuntu Live and it is operational but when we unplug it from the desktop computer and connect it to the NAS it lock again.
- OneCD
Does this drive need to remain password-locked? Can you disable the password with '--security-disable PWD' ?Diejeitor wrote: ↑Mon Jan 18, 2021 1:56 am I have already seen that and indeed the problem is not there, the disk is locked by ATA password, we have managed to unlock it by connecting it to a desktop pc through Ubuntu Live and it is operational but when we unplug it from the desktop computer and connect it to the NAS it lock again.
iyes, this was done using ubuntu live and while it is in ubuntu it lets work with the disk but when installing it in Qnap it shows a red led and when applying hdparm -I it shows that it is unlocked but frozen.OneCD wrote: ↑Mon Jan 18, 2021 3:43 amDoes this drive need to remain password-locked? Can you disable the password with '--security-disable PWD' ?Diejeitor wrote: ↑Mon Jan 18, 2021 1:56 am I have already seen that and indeed the problem is not there, the disk is locked by ATA password, we have managed to unlock it by connecting it to a desktop pc through Ubuntu Live and it is operational but when we unplug it from the desktop computer and connect it to the NAS it lock again.
- OneCD
