Hi.
I'm thinking of upgrading my TS-412 Qnap Nas with 4x4Tb WD Red drives (WD40EFAX).
Those are not in compatibility list at https://www.qnap.com/en/compatibility/? ... category=1 but shouldn't they fit just fine as Nas Drive series from WD?
WD Red (WD40EFAX) for TS-412
Re: WD Red (WD40EFAX) for TS-412
Dont use SMR drives ..get CMR ..then 4TB work fine
just remember the 16TB volume limit
So, WD40EFZX should be fine then?
16 Tb limit is ok, I have them in RAID5 at the moment.
Red Plus is CMR ..so that is fine..yes
Thank you very much.
