Hi
I have TS269Pro installed with 2 x WD40EFRX and one the drives is giving warning of failure. I intend to replace it with the same model but it seems like WD have replaced it with the WD 40EFZX.
Will the new model work? I could not find it on the compatibility list but I guess because the drive is too new and QNAP does not test new models of drives with the TS269Pro anymore.
Any inputs will be welcomed. Thank you
WD 40EFZX for TS269Pro
Re: WD 40EFZX for TS269Pro
any same or larger size disk will work..make sure it's nas rated and not smr
Great. Will replace and update on the outcome here. Thank you
Replaced and confirmed working fine. All good. Thanks
