Hi All,
So I am trying to make it so my Plex server does not transcode. This Qnap just can not handle it while trying to stream.
I made two mkv files from a couple of my Blu-rays.
1) The Hobbit: Desolation of Smaug (1080p/27mps/DCA 5.1)
2) Batman Returns (1080p/16MPS/TrueHD 5.1)
The Hobbit streams fine, sounds and looks. Batman skips and buffers while I transcodes. In the stream information, the video is doing a copy, but the video is transcoding. Any idea as to why? I figured it it could handle a 27mps, the 16 wouldn't transocde. So I am using "original" format on my Plex client. I see this issue with both my main client, Roku 4, and my windows machine which I used for test.
Plex and Transcoding on TS-451
Re: Plex and Transcoding on TS-451
apparently a big issue for many, because it is a client request to the server, so if the client cannot request the untouched file, the Plex server transcodes it.
you can always check here
https://forums.plex.tv/categories/qnap/p1
I have looked there some. No real answers so far.
What I find strange is that I tried Zootopia at 30mps and it works fine (no transcoding)
I would think if set it to original, it will just give it.
So I think it has something to do with VC1 and playing it on a Roku. How can I transcode my VC1 mkv file into something like mpeg4?
- Spider99
Try handbrake
Tim
TS-853A(16GB): - 4.3.4.0483 - Static volume - Raid5 - 8 x 4TB HGST Deskstar NAS
Windows Server + StableBit Drivepool and Scanner ~115 TB Backup Server
TS-412 & TS-459 Pro II: Retired
Clients: 3 x Windows 10 Pro(64bit)
What options would I do to do that? It takes a long time to use handbrake so I want to make sure I can get it right without trying 10 times.
- Spider99
you will have to experiment as it may well be different for each file depending how its encoded in the first place
looking at your batman video it could be the true hd that is not supported by the client and needs to be trans coded even if the video does not and as its all one file then the new audio has to be mixed into the new file and may account for the choppy playback
Tim
- QNAPJames
- QNAP Staff
I am moving this thread to a newly created subforum.
NAS: QNAP TS-464T4 Special Edition + Seagate IronWolf 125 3.84TB SATA SSD * 4 (RAID5)
Backup: QNAP TR-002 + Seagate IronWolf 10TB SATA HDD *2 (RAID0)
Networking: QNAP QSW-1108-8T 2.5GbE Network Switch
