Plex Media Server on a TS109II?
Plex allows you to aggregate all your personal media and access it anywhere you go. Enjoy your own media on all your devices with the Plex Media Server.
whityoulookinat
Post by whityoulookinat »
Hi There - does anyone know if it is possible to load the Plex Media Server app on a TS-109II? If so what steps to follow?
(I downloaded the PMS QPKG file from the QNAP Apps Centre, put it on the public folder, but clicking on it only gives some form of script listing and then no response).
Any help most welcome - thanks in advance of any replies.
dolbyman
Re: Plex Media Server on a TS109II?
Post by dolbyman »
no Plex is no longer supported on old ARM series CPU's
whityoulookinat
ahh - ok - many thanks for update.
Return to “Plex Media Server”
