Hi all,
new lg-smart-tv - ts259pro fw 3.7.3
ts, latest pms x86 - installed
tv, app installed
I want to stream my media-data to my new smart-tv.
NAS, connection fails.
after re-install/re-boot - one single session possible.
registered, in pms
added
name -for media server-
added several media folders
could not find option to fix or set IP/MAC
smart tv-app
cannot access https...../link (error 404)
Today/now - on QNAP - again connection fails - to/with pms
What can I do?
TIA, boxida
pms qpkg and ts259pro
TS-109Pro with Qraid1 - FW 3.1.0807T - 1 1 WD20EADS-00R6B0 - USB WD15EADS-00R6B0
Start 2008
TS-119 FW 3.7.3 - WD30EFRX - EXT4
TS-259Pro+ FW 3.7.3 - 2 WD40EFRX - EXT4 - Single Mode
Start 01.11.2010 18h/ 08.08.2012/ current 22.11.2013
SS-439 3.4.4 - 4 WD Scorpio blue 750GB, EXT4 Raid 5
Start 14.03.2012
Start 2008
Start 14.03.2012
Re: pms qpkg and ts259pro
first update that ancient firmware
latest is 4.2.6 build 20170905
hi,
my qnap works fine, no issues so far with this FW.
Does plex habe issues with older fw versiones?
if so, wich version supports alder qnap-FW versions?
And where can download/get it?
Thank you.
Regards, boxida
Thank you.
Regards, boxida
Start 2008
Start 14.03.2012
Start 2008
Start 14.03.2012
