Setup:
- This is on a TVS-1282 running 4.3.4.0551 (I'm slow to update to ensure things are relatively stable, but recognize it's time to do that)
- I have Plex Media Server QPKG installed v1.13.5.291 (the version QNAP offers through AppCenter, not the latest directly from Plex)
- Secure (https) connections is enabled in QNAP General Settings to access the NAS using a LetsEncrypt cert
- MyQNAPCloud is enabled
- Network Access Protection is enabled
- I am behind a router that has the appropriate Plex TCP/UDP port open
When I access the Plex Server web interface I get a constant "Looking for servers..." message.
I've tried different URLs
with/without https
using my ip address, and the MyQNAPCloud URL.
It used to work just fine, but hasn't in months.
What next?
Any thoughts on where should I start looking/testing first?
Do I ditch the QNAP version of Plex and go for the latest version?
Update QTS?
Try disabling HTTPS?
Are there any services that Plex is dependent on that I need to check and see if they are running?
Something else I'm missing?
Thanks!
