Some advice
Plex allows you to aggregate all your personal media and access it anywhere you go. Enjoy your own media on all your devices with the Plex Media Server.
Darksong
Some advice
Post by Darksong » Thu Jan 28, 2021 7:38 am
I’ve bought new discs for my TV471 and as I reset the system I need to load back up plex, which needs Sonarr to run. I followed some online guides and added a multimedia folder with some sub folders for films and tv shows, but when I go to download the shows from plex it says I need to select path, however I can’t find the path that will link me with the multimedia folder, where I need to tell Sonarr to send the data. Does anyone have any advice on how I can add the correct path?
dolbyman
Re: Some advice
Post by dolbyman » Thu Jan 28, 2021 7:46 am
I think there was an issue with Plex and the "Multimedia" share, use a different share and test again
Darksong
Re: Some advice
Post by Darksong » Thu Jan 28, 2021 8:40 am
Thanks, I’ll try that.
Return to “Plex Media Server”
