Plex Server needs to be updated for QTS 5.0
Plex allows you to aggregate all your personal media and access it anywhere you go. Enjoy your own media on all your devices with the Plex Media Server.
DennisGerik
First post
Post by DennisGerik »
Just installed QTS 5.0 Beta and Plex stopped working.
Current versions are not supported on QTS 5.0 Beta...says to install to a <= QTS 4.9.9 version.
Anyone found a solution for this issue on QTS 5.0 Beta?
dolbyman
Re: Plex Server needs to be updated for QTS 5.0
Post by dolbyman »
let the Plex team know (via Plex ticket or forum)
Trexx
Ask me anything
Post by Trexx »
Odds are they may not put a huge amount of effort into fixing that since it is the first beta release for limited number of modes.
Paul
UPS: CP AVR1350
markand
Post by markand »
I ran into this too. Is there a way to downgrade my QTS 5.0 install to QTS 4.x?
liamtoh1
Getting the hang of things
Post by liamtoh1 »
I am using PlexMediaServer-1.23.3.4743, which is probably modified version made to work with QTS 5.0 Beta. I downloaded it from https://forums.plex.tv/t/cant-run-or-in ... eta/726710 and it seems to be working so far.
TS-453be with QM2-2P10G1TA (2x1TB SSD as Vol1; 4x14TB HDD as Vol2); Plex
Badlock
Post by Badlock »
The QTS 5.0.0 Beta release note mentions that Plex is temporarily not supported. No mention of Plex after that.
Is Plex supported in the more recent revision of the 5.0.0?
dolbyman
Post by dolbyman »
QTS is out of BETA for a while....
holger_kuehn
Easy as a breeze
Post by holger_kuehn »
the recent "PlexMediaServer-1.25.0.5246-cb2507e4d-aarch64.qpkg" from Plex-Download-page works just fine for me on QTS 5.0.0.1858
NAS (production): TS-1635AX FW: QTS 5.1.4.2596 build 20231128
NAS (backup): TS-1635AX FW: QTS 5.1.4.2596 build 20231128
Data (QTier): [RAID-6] 4 x 4TB Samsung 870 QVO Sata
Data (HDD): [RAID-6] 7 x 18TB Exos
RAM: 8 GB (QNAP shipped)
UPS: CyberPower CP900EPFCLCD
Usage: SMB with rclone (encrypted)
NAS: TS-873U-RP FW: QTS 5.1.4.2596 build 20231128
BACKUP: 4TB Synology DS214 FW: DSM 7.0.41890
Usage: SMB, Backup Domain Controller
Badlock
Post by Badlock »
Thank you for your feedback!
Went ahead and updated to the latest QTS 5.0.0.1858 and it is indeed working fine with Plex Version 1.24.5.5173.
I was worried that the Plex support was removed like on the HybridDesk station and that I would have troubles downgrading QTS after a major update.
dolbyman
Post by dolbyman »
Plex Server is still actively advertised by QNAP, so I doubt they would remove this (and it's probably developed by Plex themselves anyways)
https://www.qnap.com/solution/plex-best-nas/en/
Return to “Plex Media Server”
