Plex not loading
Plex not loading
I am on the home page of my locally hosted plex server. I am running version 1.23.4. I stopped it, then started it back up again, but it still doesn't load. It just shows a spinner.
Re: Plex not loading
check your Plex logs to see whats going on
I see this one a lot:
ERROR - Network Service: Error in browser handle read: 125 (Operation canceled) socket=-1
- Easy as a breeze
You should post your logs on the plex-forum, usually you'll get there a specific hints what's wrong. Have you rebooted your NAS? I had some occasions where only this solved some issues leading to your described behavior.
NAS (production): TS-1635AX FW: QTS 5.1.4.2596 build 20231128
NAS (backup): TS-1635AX FW: QTS 5.1.4.2596 build 20231128
Data (QTier): [RAID-6] 4 x 4TB Samsung 870 QVO Sata
Data (HDD): [RAID-6] 7 x 18TB Exos
RAM: 8 GB (QNAP shipped)
UPS: CyberPower CP900EPFCLCD
Usage: SMB with rclone (encrypted)
NAS: TS-873U-RP FW: QTS 5.1.4.2596 build 20231128
BACKUP: 4TB Synology DS214 FW: DSM 7.0.41890
Usage: SMB, Backup Domain Controller
I have the same issue..... updated plex to 1.23.4 in app center and then no connection to the server.....
Steffen Lav
Copenhagen, Denmark
TS-453A w/ 16GB RAM & 4*Segate SATA3 4TB ST8000VN000/NAS -- FW: QTS 4.3.3, Backup: QNAP TS-239 w/ 2GB RAM & 2 * Seagate SATA3 6TB ST6000VN000/NAS -- FW: QTS 4.2.3
Copenhagen, Denmark
Just reboot the NAS and check again
