[SOLVED] PMS on QNAP - “Not Authorized”
Plex allows you to aggregate all your personal media and access it anywhere you go. Enjoy your own media on all your devices with the Plex Media Server.
Ak1rA
Post by Ak1rA »
QNAP, TS-251A, OS Version 4.5.4.1741
PlexMediaServer-1.24.2.4973-2b1b51db9
after a normal manual installation of PlexMediaServer I got this message
https://imgur.com/a/u1MXhr1
I just tried the workaround but doesn't work
Stop Plex
Create a Shared Folder named PlexData
Restart Plex
Stop Plex
Open FileStation
Navigate PlexData/Plex Media Server
Delete Preferences.xml
Exit File Station
Start Plex - wait a minute for it to start up
Open an INCOGNITO window to http://qnap-ip:32400/web
Now start setup
Can you help me?
Thanks.
QNAP TS-251A 2GB + 2x4TB
UnRaid i5-3570T 8GB 14TB
holger_kuehn
Easy as a breeze
Re: PMS on QNAP - “Not Authorized”
Post by holger_kuehn »
You need to claim your (new) server (instance). Just open http://<IP of NAS>:32400/web and log into your Plex account.
NAS (production): TS-1635AX FW: QTS 5.1.4.2596 build 20231128
NAS (backup): TS-1635AX FW: QTS 5.1.4.2596 build 20231128
Data (QTier): [RAID-6] 4 x 4TB Samsung 870 QVO Sata
Data (HDD): [RAID-6] 7 x 18TB Exos
RAM: 8 GB (QNAP shipped)
UPS: CyberPower CP900EPFCLCD
Usage: SMB with rclone (encrypted)
NAS: TS-873U-RP FW: QTS 5.1.4.2596 build 20231128
BACKUP: 4TB Synology DS214 FW: DSM 7.0.41890
Usage: SMB, Backup Domain Controller
Ak1rA
Post by Ak1rA »
holger_kuehn wrote: Sun Sep 12, 2021 3:30 pm You need to claim your (new) server (instance). Just open http://<IP of NAS>:32400/web and log into your Plex account.
it's not the right way, every time I will try to go on http://<IP of NAS>:32400/web (after log on) I got the "Not Authorized" message.
I found a solution: complete the installation into a lan without any other Plex instance (I have the main server on a UnRaid installation).
Return to “Plex Media Server”
