QSirch is currently offline
mcassellis
Post by mcassellis »
When I open QSirch I get the following message (See attached files):
"Qsirch is currently offline. To use Qsirch, please contact the administrator to enable this service on management center."
QSirch is enabled (see attached file).
This message seemed to start after I purchased and activated a pro license. It started successfully after the initial install.
I have stopped/started/uninstalled/reinstalled/rebooted my NAS and I still get the same error. After uninstalling QSirch I checked /share/CACHEDEV1_DATA/ to see if there was anything left over but the QSirch directory was removed properly.
Any ideas?
Many thanks
mcassellis
Re: QSirch is currently offline
Hello
Its working now - After I cleared my browser history (Safari).
Hope this helps others.
Return to “Qsirch & Qfiling”
