Qsirch consuming 100% of memory?
zyphaz
Post by zyphaz »
Hi all,
I've noticed in the past few weeks that Qsirch can run away with memory consumption. I'm running a TVS-872XT (i5-8400T) with 64GB of RAM and checking top...shows that QSirch is consuming as much phys + virtual memory as it can grab.
Mem: 65337156K used, 493800K free, 101592K shrd, 60032K buff, 531656K cached
CPU: 33.1% usr 16.5% sys  0.0% nic 10.2% idle 39.5% io  0.0% irq  0.5% sirq
Load average: 20.35 26.98 25.89 3/3511 4250
  PID  PPID USER     STAT   VSZ %VSZ CPU %CPU COMMAND
14380 10390 admin    D   72987m110.4   3  0.3 /share/CACHEDEV15_DATA/.qpkg/Qsirch/bin/python -m bin.run_file_listener -n 0
I have the latest version of Qsirch installed; 5.1.3 and I'm running QTS 4.5.4.1741
dolbyman
Re: Qsirch consuming 100% of memory?
Post by dolbyman »
If this is causing issues with your NAS, report this to QNAP via ticket, only this way they will know about it
lgkahn
Post by lgkahn »
i had to remove it.. i have a machine with 32gig ram the cpu was the culprit it made the machine unuseable as it tried to index our large song music collection.. piece of junk (and yes we own the cds.. my wife keeps buying more .. about over 2000 cds now)
Return to “Qsirch & Qfiling”
