How to detele hosts in shared folder access list?
calaver4
Post by calaver4 »
how can I delete an host inserted in the shared forlder access list table for NFS or Microsoft Networking? For this access list there is only the the "Create Host" button.
I've attached an image to better show what I'm meaning.
Thanks in advance
storageman
Ask me anything
Re: How to detele hosts in shared folder access list?
Post by storageman »
Read the manual!
You delete them from the hosts list
To edit a host, first select a host in the list and click "Edit". Then add a new entry, or change or remove the existing entry. Then click "Apply". To remove a host, first select a host and click "Delete".
calaver4
Post by calaver4 »
Storageman thanks for your quick reply, before writing this post I red the manual but I did not found the host table, also searching the word host with the search feature of the UI did not find anything.
Now I looked better and I found the host table.
Anyway I think this interface is not enough intuitive and search feature is not "smart" enough.
I think that near the create button should be a link to the host table.
Also the manual should be better if they add more screenshots.
Thanks for your support
storageman
Ask me anything
Seemed ok to me.
They are working on better user manual with more pics as in this paper.
https://eu1.qnap.com/Storage/TechnicalD ... 103-en.pdf
Return to “QES Operating System (QNAP Enterprise Storage OS)”
