Setup your Grove Indoor Environment Kit for Intel Edison
1.1 What you will need
An Intel Edison board
A Micro B to Type A USB cable
A power supply with at least 7-15V DC and 1500mA
A Wi-fi access point
The Intel Edison and NAS must be under the same LAN.
1.2 Set up Intel Edison
If you have not set up your Intel Edison, follow these guides for your respective operating system.
Windows (32-bits)
1.3 Configure and test your devices
- Step 1: Assemble the Intel Edison board
Step 2: Assemble the Indoor Environment Kit
Step 3: Connect the hardware
Use the setup tool to install the latest firmware on the Intel® Edison development board. The setup tool also lets you enable SSH and Wi-Fi* connectivity to your board, as described in the steps to follow.
Take a note of the Edison's IP address as it will be required later.
1.4 Install Node.js and required libraries
Open a terminal application on your computer and connect to Intel Edison.
Install Node.js and related libraries
root@Edison:~# echo "src intel-iotdk https://iotdk.intel.com/repos/3.5/intel ... opkg/i586/" > /etc/opkg/intel-iotdk.conf
root@Edison:~# opkg update
root@Edison:~# opkg upgrade mraa upm
root@Edison:~# opkg install nodejs
Create your device in QIoT Suite Lite
2.1 Install QIoT Suite Lite
Install QIoT Suite Lite from the QTS App Center. Open and sign in to QIoT Suite Lite using the admin account. 2.2 Import a new sample application
Download the sample application file: "iot_inbox.json" from Github.
Import the "iot_inbox.json" file in the IoT Application Panel. Click the created application: iot_inbox Connect a Device by MQTTS Download Certificates Download resource info file For more tutorial, please visit this linkhttps://www.qnap.com/en/how-to/tutorial ... suite-lite
