QIoT File node location to use
QIoT technology to allow you to explore potential IoT business opportunities.
Smart home/Smart building/Smart City/
eskdale
Post by eskdale »
Hi - Does anyone know how to use the Storage - file node
If I don't precede the filename with a path I don't get an error but where is it stored?
found a copy of it at "/share/CACHEDEV1_DATA/.qpkg/container-station/system-docker/overlay/e3493d7fd7bf37e431fb7bdc9cd3c1c5b0d3a12f0835b26d14dcd8639aeaf099/upper/gate.jpg"
What path should I use to be able to access the file - Everything I try ends up with an ENOENT error inferring that the path is not valid
I'm trying to download an image from the security camera and save it to disk and then email it as an attachment
Thanks Jon
contactdarin
First post
Re: QIoT File node location to use
Post by contactdarin »
Ditto. Any progress you can share?
Dwkdiver
Post by Dwkdiver »
DITTO DITTO DITTO
can't specify or find a path to file created.
HELP!!!
Return to “QIoT”
