QIoT & myqnapcloud - MQTT unavailable
QIoT technology to allow you to explore potential IoT business opportunities.
Smart home/Smart building/Smart City/
leandre
First post
Post by leandre »
Hello every one,
I started to use QIoT because it seems interesting.There is a lots of stuff included.
I try to use the MQTT server but I have some problems : My QiotSuite is reachable with my myqnapcloud adress, I just add "/qiot" at the end.
In the .JSON file, when i want to connect a device through MQTT, there is this line : "myqnapcloudHost": "Not Available",
In QIoT suite, Settings>Administrative settings I Have this :
When I press the button "update myqnapcloud adress" there is a warning that talk about reenrolling my devices, then :
I add NAT rules for all the ports mentionned here :
https://qiot.qnap.com/blog/2017/09/21/s ... e-v1-0-41/
I don't understand, I need your experience.
Return to “QIoT”
