QIoT2.0 Node Red settings.js
QIoT technology to allow you to explore potential IoT business opportunities.
Smart home/Smart building/Smart City/
chris_gla
Post by chris_gla »
Trying to check/ modify settings for persistence (to use disk rather than RAM) and projects in QIoT. I don't see QIoT in container station- is this deliberate?
Using "system-docker exec -ti qiot-node-red bash" I don't find an editor- is any installed? VI would be fine!
Is there a way to access the QIoT filestructure from File Station?
It's clear QIoT has been well firewalled- but as I'm only really using Node Red with MQTT & https, Influx & Grafana I'm wondered if the Node Red docker container is more suited than the QIoT package?
Thanks!
Return to “QIoT”
