Hi, I'm new in this forum.
I have a TS431p
Firmware version: 4.5.3.1697
I want to use the QNAP as a MQTT broker, but I cannot find the app to install it.
Should I add the repository for this suite?
(I repeat, I'm new at this, I hope it was not a too absurd question)
Thanks in advance!
I cannot find QIOT in the AppCenter
Re: I cannot find QIOT in the AppCenter
See here
https://www.qnap.com/en/software/qiot-suite
Your NAS is not compatiblex86-based NAS (Intel and AMD processor): requires a minimum of 4 GB RAM and QTS 4.3.0 (or later).
• ARM-based NAS (32-bit): requires a minimum of 2 GB RAM and QTS 4.3.4 (or later). Supported models: TS-x31X, TS-x31P2, TS-x31XU, TS-1635.
• ARM-based NAS (64-bit, 4KB page size): requires a minimum of 2 GB RAM and QTS 4.3.4 (or later). Supported model: TS-328.
• ARM-based NAS (64-bit, 64KB page size): requires a minimum of 4 GB RAM and QTS 4.3.4 (or later). Supported model: TS-x32.
OK, Thank you very much!
I suspected it, but I couldn't find where it was clearly stated.
What about this package? :
https://www.qnapclub.eu/en/qpkg/406
Somebody has tried it?
Thanks!
Thanks!
That package is only for x86 and x64 ...so also not compatible with your ARM NAS
Ups!
OK, thanks again!
OK, thanks again!
- moody_blue
- Easy as a breeze
If you install entware you can also install mosquitto viewtopic.php?f=351&t=139781
I no longer use entware (it interfered with other qpkg's).
QNAP TS-253A 8G QTS 5.0.1.2145
Plex Media Server 1.29.0.6209
OpenHAB 3.4.0.M2
Unifi 7.2.92
Apache80 2454.8230
GLPI 10.0.3
OpenHAB 3.4.0.M2
Unifi 7.2.92
Apache80 2454.8230
GLPI 10.0.3
Curious if in the meantime on a TS-451A (x86, 4 GB) it is not available in the APP store?
Any idea?
Any idea?
QIot 2.0.009 is here (last update 2022/09/09)
https://download.qnap.com/QPKG/QIoT_2.0 ... x86_64.zip
Topic closed for necroposting
