insufficient ramdisk space
Locked
Timidfriendly
Getting the hang of things
Contact:
Post by Timidfriendly »
Hi all,
I've had ramdisk issues. I have spend hours going through all the posts I can find on the subject trying to issolate the issue and distill a solution.
The system is unable to save your settings (file = [/etc/storage.conf], section = [VOLUME 1], field = [status], value = [0]) due to insufficient ramdisk space. If restarting the server does not solve the problem please contact support for further assistance.
In the end I have, rebooted, turned off all the active apps from app center and executed de
df
command to show following results:-
Filesystem                Size      Used Available Use% Mounted on
/dev/ramdisk            139.5M    129.5M     10.0M  93% /
tmpfs                    64.0M    284.0k     63.7M   0% /tmp
tmpfs                   494.4M     28.0k    494.4M   0% /dev/shm
/dev/sda4               371.0M    243.0M    128.0M  66% /mnt/ext
/dev/md9                509.5M    115.5M    394.0M  23% /mnt/HDA_ROOT
/dev/md1                922.7G    815.5G    106.7G  88% /share/MD1_DATA
/dev/md0                  2.7T      1.3T      1.4T  48% /share/MD0_DATA
tmpfs                     1.0M         0      1.0M   0% /mnt/rf/nd
I am now able to access the NAS through the GUI, but i'm concerned about the size of the ramdisk — 93% — seems almost full.
*Is that normal?
*how can I clear it — there must be a command to empty the ramdisk?
I have a TS-459 pro (First itteration: Intel Atom Dual Core 1.66GHz, Memory 1GB DDRII) running QTS v4.2.0 (2015/11/18)
Any help, insights would be greatly appreciated.
TS-459 Pro (First iteration: Intel Atom Dual Core 1.66GHz, Memory 1GB DDRII) running QTS v4.2.5 &&
TS-453 Pro (8gb) running QTS v4.3.3
schumaku
Contact:
Re: insufficient ramdisk space
Post by schumaku »
Timidfriendly wrote:I am now able to access the NAS through the GUI, but i'm concerned about the size of the ramdisk — 93% — seems almost full.
No, it still has 7% free space.
Timidfriendly wrote:*Is that normal?
Yes. Answered a hundred times already.
[~] # df
tmpfs 64.0M 468.0k 63.5M 1% /tmp
This is a TS-459 Pro II, QTS 4.2.0 20151118.
Timidfriendly wrote:*how can I clear it — there must be a command to empty the ramdisk?
Go for it - remove anything ... and be ready to say good bye to the data on your NAS. No, you are not supposed to remove anything. Healthy NAS operations require the space, and temporary used space is cleaned up normally.
Timidfriendly
Contact:
@schumaku
Thank you. Very helpful.
Question: Did you have a bad day? Your response came across as very irritated.
I'd like to remind you that Noobs —like myself— ask these questions because despite our best effort, we realise we are ignorant of the answers and wish to learn from gifted people like yourself.
Graciousness is a choice and a sign of maturity & sowing graciousness brings forth a harvest of thanks and respect.
Just saying ;-)
brenry
Post by brenry »
the sourpuss baby boomer keyboard warriors of schumaku and pwilson is what irritated me most years back when I opted to go with Qnap because of LonTV positive views on the units. Almost as much irritation that i'm having with tmpfs causing failures.
jaysona
Been there, done that
Post by jaysona »
It is generally customary to read site rules when joining a forum.
viewtopic.php?f=5&t=60
No need to dredge up an almost six-year old thread.
Necro-posting is also not allowed. This is the practice of posting in stale, inactive or dead topics. A topic is considered dead if it hasn't been updated for over 1 year.
*Mods notified*
RAID is not a Back-up!
H/W: QNAP TVS-872x (i7-8700. 64GB) (Plex server & encoding host) / TVS-EC1080 (32Gig ECC) - VM host & seedbox
H/W: Asustor AS6706T (32GB) / Asustor AS7010T (16GB) (media storage)
H/W: TS-219 Pro / TS-509 Pro
Router1: Asus RT-AX86U - Asuswrt-Merlin - 3004.388.6_2
Router2: Asus RT-AC66U - Asuswrt-Merlin - 386.12_6
brenry
Post by brenry »
have had mine since 2016 just never bothered registering here. There was a thread posted last week about this issue and many threads going back to 2013 where the tmp was restricted to a measly 32 meg of ram. Later only boosted to 300 megs. Which had many people extremely irritated over qnap's poor support network. This actually is a huge issue now that people started to migrate to container dockers causing issues that can't be remedied or cleared out. Then ya got smart a$$ boomers like the dude above not helping just running people off. Not being sour about it. Just dreading having to lose 16 tb to fix random issues that started to occur. So .. appreciate your advice on a faq. I'm not a millenial or the sour puss generation just the one inbetween, and man I'm frustrated reading all the forum posts seeing other frustrated people.
jaysona
Post by jaysona »
I'm in the in-between category as well, but I do get annoyed AF (as do others) when people are too lazy to use the search and post questions that have already been answered - multiple times in most cases.
AlastairStevenson
Experience counts
Post by AlastairStevenson »
the sourpuss baby boomer keyboard warriors of -------- and pwilson is what irritated me most years back
Sady, no longer with us.
He was very knowlegable and helpful, but gave tough love.
OneCD
Post by OneCD »
Locked
Return to “Users' Corner”
