I try to install Linux at Linux station, I tried 3 different versions on ubuntu, they all failed at 51% of installation, anyone had similar problem and how to fix?
my device is TS-251+, Firmware version 4.3.3.0095 Build 20170216
linux station installation failure
Re: linux station installation failure
I had this a few times due to a bug where the installation process was removing and not updating the default gateway in the Virtual Switch which broke the route to the internet, stopping the follow-on download.
But it was a Beta 4.3.0 version much earlier than yours and it was fixed in an updated build.
Check the gateway status with a 'route' command at a shell prompt.
It should be a known problem - maybe best to submit a HelpDesk ticket to see what the fix is : https://helpdesk.qnap.com/index.php?/Tickets/Submit
