i'm using ts-231+
i did installed opkg in nas and installed python3 , python3-pip using opkg
it was great to here,
but forget the expectations, i had meeting error message when i commanded like this.
- pip3 install scapy
error-------------------------------------------------------------------------------------------------------
Collecting scapy
Using cached scapy-2.3.3.tgz
Complete output from command python setup.py egg_info:
Traceback (most recent call last):
File "<string>", line 1, in <module>
File "/share/CACHEDEV1_DATA/.qpkg/Entware-ng/tmp/pip-build-b9zug6o0/scapy/setup.py", line 36
os.chmod(fname, 0755)
SyntaxError: invalid token
Command "python setup.py egg_info" failed with error code 1 in /share/CACHEDEV1_DATA/.qpkg/Entware-ng/tmp/pip-build-b9zug6o0/scapy/
i did spend time too much for finding solution ... but i couldn't
i need to hlep somone ...
python3- pip (scapy) install issue when using opkg
- OneCD
Re: python3- pip (scapy) install issue when using opkg
Hi and welcome to the forum.
Try this instead:smksky wrote:- pip3 install scapy
pip3 install setuptools scapy-python3
first thanks to replyOneCD wrote:Hi and welcome to the forum.
Try this instead:smksky wrote:- pip3 install scapyCode: Select all
unfortunately i did already use this solution
- OneCD
Unclear - did it work or do you still have an error?
ps. really thanks to your kinds !!
