My Cloud
- hakannordell
My Cloud
Well, my first corner of my own
Today I received a notice to update to 4.4.3.0154 Build 20170413. It was recommended that to launch a testprogram to control that all software is compatible with 64-bit. I downloaded the test program and tried to install it on the 471. It failed, because it requires Python < version 2.7. I tried to install Python 3, but it was not accepted, so I installed Python 2.7.12. Then I run the test program, and that said that QMono is´t compliant.
Then I thought I shoud install the program on the 1635 and 431, but no. Not any of these have the Python 2.7, only Python3, and I do not want to risk anything.
So, nothing to update today But I updated the ReadyNas yesterday, from 4.4.3 to 6.6.1
[Plex Runner] QNAP TVS-471 (QTS 4.3.4.0435), Intel Core i7-4790S, 16GB RAM, 768GB 850 Pro SSD for System and Transcoding, RAID-1, Shared APC 750
[Data Holder and Plex Runner] TS-1685 (QTS 4.3.4.0435), Qtier, 16GB RAM, 1,5TB 850 EVO M2, 512GB 850 Pro and 512GB EVO SSD, 32TB RED RAID-5,, Shared APC 750 and 10 GbE SFP+
[Master Backup] QNAP TS-1635 (QTS 4.3.4.0435), 16GB RAM, 512GB Pro SSD, 24TB RED RAID-5, Shared APC 750 and 10 GbE SFP+
[Seconary Backup] QNAP UX-500P, 20TB RED RAID-5, Shared APC 750
[Torrent Runner] QNAP TS-431 (QTS 4.3.4.0435), 0TB RED RAID-1, Shared APC 750
[Off-Site Backup] NetGear ReadyNAS Ultra 6 (ReadyNAS OS 6.7.5), Seagate 12TB RAID-0, Singel APC SC 620
[Other Cool Stuff] Linksys LRT224 DualWAN, Fibaro HC2
- hakannordell
Re: My Cloud
I got a version of Python that works for the 1635 (worked for the 431 also). I downloaded it from
https://www.qnap.com/en/app_center/con_ ... 2.2&seq=48
and after I installd the testprogram, it just say that QMono is not compatible.
I really don´t need the QMono on the 1635. I installed it because Radarr and Sonarr was dependent on QMono, but I don´t find any downloader that fits the 1635 and the sonarr/radarr (471 is running sonnar/radarr together with QBittorrent). So I deleted all the programs an updated firmware. Well, not yet. The disk is doing the weekly synchronizing. I will be back
- hakannordell
Re: My Cloud
Updated the 1635 to FW 4.3.3.0154 without problem, but when I were going to update the 431, the update was gone It´s still on the download page, but not by automatic install. Hmm.. Think I skip to force the update right now. Just in case QNAP discoverd some problem with the update. So, for now, just the 1635 is updated
Ordered and installed the SFP+ card in the 471 a week ago. But my supplier did´t know what cabel I needed, so I ordered it direct from QNAP i Taiwan. Some of the cables is just working with the brand of the cables (HP and Cisco) so I did´t want to gamble. Now, after the cable was stuck in the customs, and I was forced to pay tax, the cable is going to be almost twice as expencive, as if I have bought here in Sweden Well Money to pay for learning.
- hakannordell
Re: My Cloud
I really like the look and size of 1635. It's soo ... masculine Wondering if I will not buy me a 1685. The problem is then that 471 becomes unemployed, as I will probably put the Plex server in 1685. The question of how to use it then? Anyone who has any suggestions besides running dual Plex servers? I can use it as a backup instead of Netgear or 431, but it's too good for it, and in addition, the UX500P now connects to 1635 (which can be fixed separately).
- Been there, done that
Re: My Cloud
i'll host an off-site backup destination for you ...... you can send it to me
Production :
TVS-673 4.3.4 0387
4 X 3TB WD RED : 1 X 4TB HGST DESKSTAR R5
32GB
LAN-10G1SR-D, FiberHal for Cisco SFP-10G-SR
NETGEAR ProSAFE SS3300-28X
Backup :
TS-469L 4.3.4 0387
4 X 3TB WD RED R5
3GB
Located detached garage .. cheap offsite solution ...
2nd TS-469L awaiting drives and reassignment for front-line duty .......
TVS-673 4.3.4 0387
32GB
Backup :
TS-469L 4.3.4 0387
4 X 3TB WD RED R5
3GB
- hakannordell
Re: My Cloud
I really don´t see that a another off-site backup, would set my 471 in work if I buy a 1685. Allready got 3 backup sites/stations. But.. thankskherr4377 wrote:i'll host an off-site backup destination for you ...... you can send it to me
- hakannordell
Re: My Cloud
Could´t control myself and downloaded the FW 4.3.3.0154 from the TS-431 website on QNAP.
But I just ended up with App install failed due to file format error .
Re: My Cloud
had the same issue with my 673 firmware .... ended up choosing a different dl location (global i think) and it was fine then
Production :
TVS-673 4.3.4 0387
32GB
Backup :
TS-469L 4.3.4 0387
4 X 3TB WD RED R5
3GB
TVS-673 4.3.4 0387
32GB
Backup :
TS-469L 4.3.4 0387
4 X 3TB WD RED R5
3GB
- hakannordell
Re: My Cloud
Choosing global (instead of Euro) but same message. Well, I try in again in a week or so.kherr4377 wrote:had the same issue with my 673 firmware .... ended up choosing a different dl location (global i think) and it was fine then
- hakannordell
Re: My Cloud
Reorganized 431 because I always have a swap area on the hard drive. I installed a SSD as a system disk and we will see if it has the intended effect. I also changed the raid to 5, instead of raid 6... becuase I dedicates one bay to SSD.
- hakannordell
Re: My Cloud
And the update 4.3.3.0154 firmware for the 431, was back this morning. Just done the update and it´s still alive
- hakannordell
Re: My Cloud
Updated 471 with firmware 4.3.3.0154 and everything went well. I had installed QMono 4.8.0.520 earlier, and it should be remembered that after the firmware has been installed and the machine has restarted, you have to stop and start Sonarr and Radarr for everything to work.
- hakannordell
Re: My Cloud
Finally got my SFP + cable (CAB-DAC15M-SFPP-A02) from QNAP today, so now we'll see what it can do with the speed between 471 and 1635
- hakannordell
Re: My Cloud
Made an order today to make a final completion of my servers Now, we'll see how long it takes for QNAP to deliver
- hakannordell
Re: My Cloud
Now I have been notified. It is expected to arrive at the supplier on 1 May
