HELP
Today Qnap TS419P II rebooted it self?? once it had rebooted I could not logon had to run qfinder pro.
This is the system message I have?
OMG I'm sick to my stomach!!
I Have removed all 4 single drives just incase No Raid drives.....
Firmware Version of Qnap 4.2.5,
MacOS 10.12.4
Please help me I don't want to lose my files
Regards,
William
QNap rebooted lost configuration file...
Re: QNap rebooted lost configuration file...
there is not x15 ... and no 9 drive bay units (915)
do you mean 419p ?
can you log on to the system via ssh ?
I think I dont need to mention how important backups are ..even more so when not running a raid
do you mean 419p ?
Sorry Yes TS419P II
I can Log on to the System using Terminal is this fine?
can you issue
cat /proc/mdstat
This is what I go from the Terminal window....dolbyman wrote:can you issue
cat /proc/mdstat
[~] # cat /proc/mdstat
Personalities : [raid1] [linear] [raid0] [raid6] [raid5] [raid4]
unused devices: <none>
Regards,
William
ImacWillie
I did a ls -r
This is what I got...
[~] # ls
index_default.html
[~] # ls -r
index_default.html
[~] # ls -alh
drwxr-xr-x 3 admin administ 1.0k Jul 18 2007 ./
drwxr-xr-x 18 admin administ 1.0k May 16 07:39 ../
lrwxrwxrwx 1 admin administ 6 Apr 13 01:58 .BitTornado -> ../tmp/
-rw-r--r-- 1 admin administ 163 May 16 08:32 .bash_history
-rw-r--r-- 1 admin administ 175 Oct 9 2004 .bash_logout
-rw-r--r-- 1 admin administ 161 Oct 9 2004 .bash_profile
-rw-r--r-- 1 admin administ 1.6k Jul 18 2007 .bashrc
-rw-r--r-- 1 admin administ 27 Jan 29 2007 .profile
drwx------ 2 admin administ 1.0k Jun 24 2008 .ssh/
-rw-r--r-- 1 admin administ 6.4k Jul 11 2007 index_default.html
BTW I had 4.3.3 firmware installed.
[~] # ls
index_default.html
[~] # ls -r
index_default.html
[~] # ls -alh
Re: ImacWillie
Are the HD's bakc in their scoket, and is the NAS running 24/7?ImacWillie wrote:I did a ls -r
[~] # ls
index_default.html
[~] # ls -r
index_default.html
[~] # ls -alh
If so, a backupfile should be created every wednesday, if i am correct.
a config backup does not help when there is no volumes mounted
get help from qnap
get help from qnap
Yes it was, So How do I restore?
PLease follow up the recoomendation by dolbyman.ImacWillie wrote:Are the HD's bakc in their scoket, and is the NAS running 24/7?
Raise a ticket to qnap.
I truelly thought that a config file should bring you back online, but i am totally wrong.
