Low performance and high CPU after FW upgrade to 4.3.3
Greetings,
we have an TS-1679U-RP with 16 WD4000F9YZ-09N20L0 HDs used as a respository for our veeam backup.
Last week I upgraded from 4.1.0 to 4.3.3, since then we have performace (throughput not higher than 7 MB/s) problems and a high CPU IO WAIT (~33%) and CPU usage (~35%)
after running "top" I found that kswapd0 is resonsable for the high cpu rate. After rebooting the NAS the CPU goes down to normal but as soon as the backup starts the cpu goes up and stays that way.
Any Ideas?
Thx,
James
Any Ideas?
Thx,
James
Re: Low performance and high CPU after FW upgrade to 4.3.3
what raid level and storage configuration are you using?(thick or thin ..etc)
- Toxic17
perhaps Raid Scrubbing is running?
Regards Simon
Qnap Downloads
MyQNap.Org Repository
NAS: TS-673A QuTS hero h5.1.6.25734 • TS-121 4.3.3.2420 • APC Back-UPS ES 850G2
Network: VM Hub3: 500/50 • UniFi UDM Pro: 3.2.12 • UniFi Network Controller: 8.1.127
USW-Aggregation: 7.0.50 • US-16-150W: 7.0.50 • US-8-60W: 7.0.50 • 2x USW Mini Flex 2.0.0 • UniFi AC Pro 6.6.69 • UniFi U6-LR 6.6.69
UniFi Protect: 3.0.26/8TB Skyhawk AI • 3x G3 Instants: 4.70.39 • UniFi G3 Flex: 4.70.39 • UniFi G5 Flex: 4.70.39
Qnap Downloads
I guess you could be right .. is the scrubbing invoking the kswap ?Toxic17 wrote:perhaps Raid Scrubbing is running?
- Trexx
from googling:
How much memory do you have? Please paste the output of the following:kswapd is managing swap space in response to memory demands greater than physically available for all processes.
It is process agnostic, it is only interested in what pages are access and when (it is more complex than this of course but to keep things simple we may as well view it this way).
So the real question is "what processes have the greatest burden on memory that are causing kswapd to need to page all the time".
That is most easily answered using 'top' and switching to memory usage sort mode.
free
Paul
UPS: CP AVR1350
UPS: CP AVR1350
We are using RAID 5, 30 TB thin
no
[~] # free
total used free shared buffers cached
Mem: 1859532 1579680 279852 251036 575024 261376
-/+ buffers/cache: 743280 1116252
Swap: 530108 1172 528936
no
[~] # free
- Trexx
You aren't short of memory, as you have roughly 1GB free of your 2GB of memory. And your minimal swap usage also confirms that as well.
Thin LUNs are by their very nature causing some overhead/performance loss do to allocating blocks on demand. And that also would correspond to CPU IO Wait (waiting for disk I/O) as new blocks are being allocated/mapped.
Have you run SMART tests on your drives lately or a check filesystem?
Paul
UPS: CP AVR1350
UPS: CP AVR1350
Same problem here on a QNAP TS-670 Pro since FW 4.3.3. CPU load is around 25 % (kswapd0).
Raid scrubbing is enabled on this device.
Mem: 1865400 1694744 170656 250156 77872 1137180
-/+ buffers/cache: 479692 1385708
Swap: 17307320 1032 17306288
- Trexx
Have you opened a helpdesk ticket with QNAP? You don't say which build of 4.3.3 you are using.fichtenelch wrote:Same problem here on a QNAP TS-670 Pro since FW 4.3.3. CPU load is around 25 % (kswapd0).
Raid scrubbing is enabled on this device.Code: Select all
total used free shared buffers cached Mem: 1865400 1694744 170656 250156 77872 1137180 -/+ buffers/cache: 479692 1385708 Swap: 17307320 1032 17306288
Paul
UPS: CP AVR1350
UPS: CP AVR1350
It's build 4.3.3.0262. No ticket opened yet. I will investigate if raid scrubbing is triggering this issue.
Updated my TS-879u-rp yesterday to 4.3.3.0262 and also experiencing the same issues with kswapd0 using 25% CPU constantly and the NAS rebooting randomly.
Anyone found a solution to this yet?
I Just opened a helpdesk ticket with qnap but seeinging if anyone has a quick fix for it
I opened a Helpdesk ticket on 8/12 and no real help except the suggestion to upgrade to 4.3.3.0299 which didn't help at all. I downgraded to 4.2.5. and everything is back to normal. Will wait an see if QNAP offers a working solution. Based on the experience with the helpdesk so far I`m not very optimistic...
Did you downgrade by just downloading older firmware and uploading it via the web gui?james_66 wrote:I opened a Helpdesk ticket on 8/12 and no real help except the suggestion to upgrade to 4.3.3.0299 which didn't help at all. I downgraded to 4.2.5. and everything is back to normal. Will wait an see if QNAP offers a working solution. Based on the experience with the helpdesk so far I`m not very optimistic...
Any loss of data or configuration when downgrading?
RAID scrubbing is definitely not the cause of the problem. Got this log entry (no task was running at this time):
On my other QNAP device (TVS-882 - same firmware, 4.3.3.0299) no problems so far. This machine has 8 GB of RAM.
Type Date Time Users Source IP Computer name Content
Information 10.09.2017 20:51:16 System 127.0.0.1 localhost [Swap Memory] Swap Memory is currently been used to free out space for physical memory. When it is required to unplug disk(s) where Swap Partition(s) are located, please unplug them one by one.
- Trexx
Make sure and keep QNAP updated on any changes you have made and bugging them for a fix.james_66 wrote:I opened a Helpdesk ticket on 8/12 and no real help except the suggestion to upgrade to 4.3.3.0299 which didn't help at all. I downgraded to 4.2.5. and everything is back to normal. Will wait an see if QNAP offers a working solution. Based on the experience with the helpdesk so far I`m not very optimistic...
Paul
UPS: CP AVR1350
UPS: CP AVR1350
