Hi
How can i enable either from the GUI or Console Jumbo Frames with MTU 9000 value for my TS 453A?
Im on QTS 4.3.3 and I can not seem to find the option at all
Viktor
How to enable Jumbo Frames MTU 9000 on TS 453A QTS 4.3.3
Re: How to enable Jumbo Frames MTU 9000 on TS 453A QTS 4.3.3
Read the fine manual.
Also remember that you need to enable jumbo frames on the networking equipment (routers/switches) as well.
Hi P3RP3R wrote:Read the fine manual.
thanks
I did find however what the manual does not seem to mention :
- Once the interface is part of a Virtual Switch you can not alter its MTU or VLAN settings
so i needed to remove it from the VS and then modify then place it back
Thanks for helping
Regards
Viktor
Okay, I haven't tried that...yet.viktormadarasz wrote:- Once the interface is part of a Virtual Switch you can not alter its MTU or VLAN settings...
Great information to have here in the forum. It will probably help others (including me) in the future. Thank you for contributing to the community!...so i needed to remove it from the VS and then modify then place it back
- Johnno72
- Easy as a breeze
I confirm this information as Viktor posted. When linking multiple NIC's on the NAS they need to be in individual / normal mode, once changes have been done, they can once again be linked.viktormadarasz wrote:
Viktor
The manual's are a bit thin with this information.
OS: Win10 Professional v2004 OS Build 19041.388 x64
NAS: QNAP TS-EC2480U-RP 16G 24 Bay - Firmware: v4.4.3.1421 build 20200907. Updated from v4.4.3.1400 Build 20200817 Official
StoragePool / DataVol: Storage Pool 1 / DataVol1: Single 29.04TB - Thick Volume: 29TB
HDD's: Western Digital - Model: WDC WD4001FFSX-68JUN0 Red Pro NAS 3.5"
HDD Size: 4TB - HDD Firmware all HDD's: 81.00A81
RAID Configuration: RAID6 x 10, HotSpare x 1, ColdSpare x 1 - Network: 1GbE
UPS: CyberPower PR3000ELCDRT2U Professional Rackmount LCD 3000VA, 2250W 2U Line Interactive UPS
QNAP Hardware details required: viewtopic.php?f=5&t=68954
Remote Administration of: TVS-863+ 16G on UPS Cyberpower OLS1500E+RMcard205
