Hello all,
I have a DS-231 2 bay device. I can see the NAS on Qfinder, it has an valid IP address which I can ping. I can see the device through Windows Explorer under "Networks" as a storage device. I can log into the device through a browser and access all the utilities including creating users and shared folders but I cannot not map a drive. I have tried via both Windows Explorer and Qfinder Storage Plug & Play.
I created users with the same username and passwords as the user of the PC and granted full permissions.
I have created shared folders and added the users individually and the groups they belong to.
This thing is driving me crazy!! Please can someone help
Thank you in advance.
lellul
Unable to Map to a shared folder
- Don
Re: Unable to Map to a shared folder
Firmware versions? Error messages? Screen shots of share permissions.
Firmware version is 4.3.3.0299 Build 20170901
Error message through Windows Explorer - Windows cannot access \\192.168.2.73\Public Check spelling ....
Qfinder Storage Plug and Play - No error, just doesn't display any folders
Sorry Don I get a screen shot. I tried it in PDF and DOC. When I try to attach I get a message about the file having a wrong extension.
- Don
I think it needs to be a jpg.
Screen grab attached
Just changed a few things. It didn't make a difference, still have a problem
- Don
Please provide screen shot of share permissions for Public.
