Hi
I want to delete a shared folder, I cann't find a way to do it, any suggestion? as shown the attachment, I want delete "Download" folder, I can select it to remove.
Delete a shared folder
- OneCD
Re: Delete a shared folder
The 'Download' share is one of the default QTS shares. It can't be deleted.
I was facing the same issue. Thanks @OneCD for the answer.
