I know its not really a qnap thing, but I'm wondering how i can boot some iso/OS (like Ubuntu, debian, dban, Windows, ...) over network.
I've followd a lot of complex tutorials, without any results.
I've also tried the one on this forum, without any succes.
Its the first time Ill trie this, but I'm searching more than 30hours for a solution...
Is there any easy solution, step-by-step for this?
I already tried youtube, this forum, Serva, ... But it looks like there is no clear manual. (the most thins i read "looks like" put it on the shared tftp folder and it works).
PXE, how to make it work?
- Don
Re: PXE, how to make it work?
You can run DNSMASQ as it supports PXE boots.
Sorry to necro an old topic, but did you ever have success with this? I also tried the method listed on the other page, but could never get beyond "Error 8 at Client, User aborted the transfer"
Since enabling DHCP usually killed my network connection on the Q I also tried with my router acting as the forwarder that pointed to the Q - still no luck.
- OneCD
@Avrution, please create a new topic for your question.
