My experience with the QNAP QGD-1600P PoE Switch
Here is my experience with the new QNAP QGD-1600P PoE Switch, for anyone is planning to utilise the switch with pfSense.
First Impression on the QNAP-Guardian Smart Switch QGD-1600P – Part 1 https://poyu.co.uk/2020/05/05/first-imp ... 0p-part-1/
Installing the QNAP QGD-1600P into the cabinet – Part 2 https://poyu.co.uk/2020/05/12/installin ... et-part-2/
pfSense on the QNAP QGD-1600P – Part 3 https://poyu.co.uk/2020/05/12/pfsense-o ... 0p-part-3/
The device should be faster than the Netgate XG-7100 1U, considering it has a newer CPU which is rated faster on the QNAP QGD-1600P. But running it in VM I'm not sure how much of a overhead it does for performance. I'm currently getting full speed on my 300mb/50mb internet connection.
In the future I'm going to test whether the device can support 32GB, as I've seen Intel J4105 - Odroid-H2 supporting 32GB RAM https://wiki.odroid.com/odroid-h2/hardw ... am_modules.
Geekbench score are:
Geekbench 4 Single 1930 / Multi 5435 https://browser.geekbench.com/v4/cpu/15460132
Geekbench 5 Single 423/ Multi 1261 https://browser.geekbench.com/v5/cpu/2037017
Current Systems
QGD-1600P-4G | QNAP TS-1683XU-RP | QNAP TS-EC880U R2 | QNAP TVS-1271U | QNAP TVS-871 | QNAP TS-879 Pro | Full List
Links
QNAP QGD-1600P - First Impression on the QNAP-Guardian Smart Switch | Setting up pfSense | 32GB RAM Upgrade | Assign VLAN
Disassembly - QNAP TVS-871 - Replacing the CPU and RAM | QNAP TS-879 Pro - Replacing the RAM
All - Making the QNAP PSU 20-pin SATA Power Adapter | Setup HomeAssistant on QNAP Container using Docker | How to setup pfSense for QNAP | Run a Geekbench 4 benchmark on QNAP Container Station using Docker| Setup HomeAssistant with Z-Wave on QNAP Container using Docker
Links
Re: My experience with the QNAP QGD-1600P PoE Switch
A comment on your disk configuration. When selecting disk configuration for a critical infrastructure device like a firewall/router I think it's good to prioritize reliability. I can't find a TBW-value for the SSDs you've chosen but my guess is it's at the low end as TBW isn't specified and the product seem to be oriented toward normal laptop/desktop usage. Also you choose RAID 0 which will bring this entire functionality to a halt as soon as either disk fail and it will remain down for a complete reinstallation of the NAS. That's the reason RAID 1 is recommended in all 2-bay Qnaps and even more so if internet-connectivity depend on the reliability of the QnapYippym wrote: ↑Wed May 13, 2020 9:08 pm Here is my experience with the new QNAP QGD-1600P PoE Switch, for anyone is planning to utilise the switch with pfSense.
But the difference is very small, isn't it? It looks like around 10% here (with very few samples though so the margin for error is high).The device should be faster than the Netgate XG-7100 1U, considering it has a newer CPU which is rated faster on the QNAP QGD-1600P.
Edit: please note that in the months since I wrote the above about CPU performance the Celeron J4115 have received more samples which have changed the relation to be very different from the 10% I mention. The Atom C3558 still only have a single sample though so things could change more. It's probably better to disregard the above link and my comment about it. I'm sorry for the confusion.
More important for pfSense is that the server grade Atom C3558 support Intel Quickassist, which I doubt the desktop Celeron J4115 do. That will probably affect performance as well.
I don't know for sure but my feeling is that it's more than 10%.But running it in VM I'm not sure how much of a overhead it does for performance.
Yes I would hope so.I'm currently getting full speed on my 300mb/50mb internet connection.
Even the 9 year old Atom D2700 in my cold spare physical pfSense can manage at least 800-900 Mbit/sec in both directions on my gigabit internet connection.
Wow! Why would you need that much RAM in a firewall/router? Even with some lost on the virtualization I don't know understand why you would need more than 8 GB.In the future I'm going to test whether the device can support 32GB, as I've seen Intel J4105 - Odroid-H2 supporting 32GB RAM https://wiki.odroid.com/odroid-h2/hardw ... am_modules
I give my pfSense VM 4 GB but it will easily run on 1 or 2 GB.
It's a nice write-up you have done. I think it will be useful for many people interested in the QGD-1600P
I recommend people to do RAID-1 on my post, I did this RAID-0 cause the SSD are throw away. I'm planning to minimise the write by using the RAM Disk setting.P3R wrote: ↑Thu May 14, 2020 7:21 am A comment on your disk configuration. When selecting disk configuration for a critical infrastructure device like a firewall/router I think it's good to prioritize reliability. I can't find a TBW-value for the SSDs you've chosen but my guess is it's at the low end as TBW isn't specified and the product seem to be oriented toward normal laptop/desktop usage. Also you choose RAID 0 which will bring this entire functionality to a halt as soon as either disk fail and it will remain down for a complete reinstallation of the NAS. That's the reason RAID 1 is recommended in all 2-bay Qnaps and even more so if internet-connectivity depend on the reliability of the Qnap
System->Advanced->Miscellaneous->RAM Disk Settings. This will collate the data in the RAM and then store the data on the storage drive in interval of 4 hours.
Though I didn't state it was massive performance, just that it should be better or faster performance if only Intel pull their finger out and go out. These small increment of performance is silly when AMD is right ahead of them. Though in truth I do not know if the J4115 is a Gemini Lake or Gemini Lake Refresh, so I cannot see what instruction set it has. The Intel Quickassist looks very interesting, but I assume it doesn't have this ability.P3R wrote: ↑Thu May 14, 2020 7:21 amBut the difference is very small, isn't it? It looks like around 10% here (with very few samples though so the margin for error is high). More important for pfSense is that the server grade Atom C3558 support Intel Quickassist, which I doubt the desktop Celeron J4115 do. That will probably affect performance as well.
Guess it just balance itself out, comparing to the Netgate
My first pfSense test, didn't know what to expect. Planning to upgrade the connection to 900mb, we will see though. Got to say I'm impressed with pfSense so far, I've installed Haproxy (bye bye docker), ACME, ntopng. I've been using an Synology router previously so I'm late into the pfSense crowd.
It's not on my major list to upgrade the RAM to 32GB, happy with 8GB but there are lots of people interested upgrading RAM when visiting my site. It nice to have more additional RAM for an plex server instance, have pfSense utilise more RAM for caching, and give more memory for Netflow. But yeah overkill, but as a techie why not?
Thanks P3R, just letting people understand the use case for this device will help people get onboard the QGD-1600P. Wouldn't mind if QNAP makes a 24 port version with front interchangeable drive bays *hint* *hint*. I've contacted QNAP about the unusable rack ear, I be getting a replacement on the way.
Current Systems
Links
Links
Just updated the post on how to fix the slow upload speed, you must enable "Disable hardware checksum offload". Otherwise you be scratching your head why pfSense performs so badly.
Current Systems
Links
Links
Got the ear rack replacement from QNAP, works fine now with the RAIL-B02 rail mounting kit.
additional images:
https://poyu.co.uk/2020/05/26/qnap-qgd- ... ar-mounts/
additional images:
Current Systems
Links
Links
Just to let people know that you can install 32GB on the QNAP QGD-1600P with the Intel J4115 CPU, checkout here:
https://poyu.co.uk/2020/06/09/qnap-qgd- ... gb-of-ram/
The 8GB Gemini Lake max memory on Intel website is not true....
I was reaching my maximum memory usage so I thought I upgrade the system, 8GB should be plenty for many just thought I tell ya there's more headroom.
Current Systems
Links
Links
What is true is that neither Intel nor Qnap support anything above 8 GB. That it may work is a different thing.
If you run into any issues, Qnap may deny you support unless you restore the system to a supported configuration. This have happened so always keep the original RAM in case you should ever need support from Qnap is my advice.
While I understand that manufactures states this and that, they just cannot test everything that is available doesn't mean it doesn't work just that you on your own if you have issues. Currently for me the Switch is running perfectly fine with the additional of RAM, it was fairly easy to do so you could just buy a 4GB model and upgrade it yourself.P3R wrote: ↑Wed Jun 10, 2020 12:39 am What is true is that neither Intel nor Qnap support anything above 8 GB. That it may work is a different thing.
Not to worry, I know the drill. The old RAM is essential for RMA and any warranty, forgot to write it down in my post.
The inspiration of the 32GB of RAM upgrade came from the ODRIOD-H2, which is stated on the website that the J4105 is capable of running 32GB of RAM.
https://www.hardkernel.com/shop/odroid-h2/
Current Systems
Links
Links
Of course Intel have tested more than 8 GB RAM and know very well how it work.
The reason that they don't want to support it could be that they know it's unstable under some specific conditions, it could be marketing segmentation/politics or something else that I can't think of. We will never know, but the non-supported message is set in stone unless they change their minds, which is unlikely to happen.
Actually I didn't worry about you as you seem to be knowledgeable.Not to worry, I know the drill. The old RAM is essential for RMA and any warranty, forgot to write it down in my post.
I posted here as a warning to those less experienced users that come to read your thread but doesn't "know the drill" and understand that there can be a huge difference between "work" and "is supported".
Also, you said "...Intel website is not true..." which is incorrect. Of course the Intel website tell the truth because it state what they support, not what may work but be unsupported.
Qnap specify the operating temperature for your QGD-1600P to be 0°C to 45°C (32°F to 113°F). It will most likely work at -1°C or 46°C as well. That doesn't mean Qnap are lying, only that they don't guarantee it to work flawless outside that range. Intel do the same with their max 8 GB limit.
- Moogle Stiltzkin
yippy i spotted this, thought you may be interested for comparing notes on the qgd
https://www.youtube.com/watch?v=bIkXQFu4qfo
NAS
Network
Resources
Network
Resources
Thanks Moogle, they also got a non video review https://www.servethehome.com/our-switch ... 0p-review/Moogle Stiltzkin wrote: ↑Fri Jun 12, 2020 4:52 pm yippy i spotted this, thought you may be interested for comparing notes on the qgd
There seems to be a new QNAP Guardian models that be coming out soon without HDMI output.
https://marketing.qnap.com/resource/qgd-1602p/
QGD-1602P with C3558 or C3758
Something tells me it be expensive.....
Current Systems
Links
Links
How to setup softflowd package in pfSense to connect to your QNAP with Docker, this will help avoid putting load on your switch.
Though the report that it output is super detailed, which would mean you might need to have a lot of RAM and storage to be able to handle your use case.
https://poyu.co.uk/2020/07/12/using-sof ... ch-docker/
Current Systems
Links
Links
How to assign VLAN in your QNAP QGD-1600P with pfSense, the way it works is that the Virtual Switch auto filter the VLAN. Assigning the interface on pfSense with VLAN detection is all you need.
https://poyu.co.uk/2020/08/16/qnap-qgd- ... h-pfsense/
Current Systems
Links
Links
- SFX Group
It cant, CPU only supports 8Gb (link from Intel), With Intels support for RAM, its not about what's around to test, they are publishing the amount of ram the CPU can address, hence why you see sizes like 2Tb for the Intel Xeons, when most boards may only do 512Gb of RAM. The fact this CPU only supports 8Gb is likely the reason they moved to the Intel Atom which will do 64Gb.
https://ark.intel.com/content/www/us/en ... 0-ghz.html
Ive seen support issue on sizes for Intel complete systems (like Intel NNUC) they are more based on what RAM can be tested at the time of release, however on checking the CPU it may list 64Gb, but the Intel NUC system may say only 16Gb (as they could only find 8Gb sticks at that time).
Wasnt PFSense supposed to be via the Container Station and not Virtualization Station? That would lighten the load alot.
Many Thanks
Works fine with 32GB, please can you look at my post and see, I've checked the controller and it says 32GB max capacity. There is no 'CAN'T, it works!!!!SFX Group wrote: ↑Sat Apr 10, 2021 3:48 pmIt cant, CPU only supports 8Gb (link from Intel), With Intels support for RAM, its not about what's around to test, they are publishing the amount of ram the CPU can address, hence why you see sizes like 2Tb for the Intel Xeons, when most boards may only do 512Gb of RAM. The fact this CPU only supports 8Gb is likely the reason they moved to the Intel Atom which will do 64Gb.
You are not going to have the full flexibility of handling all the network adapters with Container Station, I recommend Virtualization Station. I don't think you can assign multiple networks with pfSense on Container Station (which I didn't think is useful for my use case.), so you will have trouble assigning VLAN, and isolating ports.
Current Systems
Links
Links
