TS-251+ Is this a known issue?
al9315
Post by al9315 » Mon Apr 12, 2021 5:54 pm
My TS-251+ has packed up. It came up as a drive fail, replaced the drive, could not re-build, and showed fan error as well.
Contacted helpdesk, reply was just - back plane board / fan failed, send to them for repair $270
It is 5 years old so I do not feel like paying 2/3 cost of a new one for repair.
I have since then read various posts about a known issue? - solder a 100ohm resistor in to fix.......... - not something I can do
My question is :-
Is/was the TS-251+ a poor buy, and 5 years is about the expectation of its life, or have I just been unlucky?
If I bought another TS-251+, can I just take the disk/s from the old one and continue as if nothing had happened, or does one need to configure the new machine, and re-import the data
Would a 451+ be a better model, or are the issues likely to be the same?
I only use my NAS as a music server, with a few thousand albums on it. I sometimes just uploaded a few new ones using Windows 10 Explorer, and dragging them from the folder into the NAS drive music folder.
Can one do this using a 4 drive system, in other words, will I still be able to have a mapped drive on my PC called say 'music' and be able to just drag & drop as I do with my Raid 1 setup ( I do not quite understand how Raid 5 works, as is obvious) !
Thank you in advance for any help, and any advice on how to learn a bit more about this (to me) complicated subject
Regards,
Ian
Ron1963
Been there, done that
Re: TS-251+ Is this a known issue?
Post by Ron1963 » Mon Apr 12, 2021 8:02 pm
At the time of introduction the bug in the Intel processor range causing this problem was not known and it is affecting more products using one of the affected processors, not only some QNAP NAS's in the x51/x53 range. What is annoying to say the least is that QNAP plays dumb about the issue although it's a well known problem as you have found out. The 451+ is internal basically the same NAS as the 251+, just 4 bays instead of 2. With same processor and bug. Buying that one at the time would not have prevented you from this situation. And yes, with another 251+ you can just swap the drives, just make sure to use the drive in the same drive bay. In fact, you can do this with many other QNAP's and here you can check: https://www.qnap.com/en/nas-migration . The current 251D looks like the direct replacement for your 251+ and has a newer Intel processor without that bug.
1x TS251, 1x TS251D, 1x TS253
al9315
Post by al9315 » Mon Apr 12, 2021 8:30 pm
Wonderful - thank you so much for your reply, not always easy to get information even with the internet.
spile
Easy as a breeze
Post by spile » Tue Apr 13, 2021 2:02 pm
Following as I have a 5 year old TS251+
I was not aware of this “issue”.
Ron1963
Post by Ron1963 » Tue Apr 13, 2021 4:17 pm
Couple of threads here on the forum, f.i. viewtopic.php?f=45&t=135089&start=195 Basically, when you get an fan error on a x51/x53 system and the system doesn't come up properly after reboot, you are affected.
spile
Easy as a breeze
Post by spile » Thu Apr 15, 2021 2:08 pm
Thank you. I will keep this thread bookmarked and my fingers crossed.
Return to “Users' Corner”
