Bash Script
Locked
nintendo1889
Bash Script
Post by nintendo1889 »
I am trying to create a single command line does two actions, one after the other. It isn't working in qnap bash. This is just an example, I know that this should be in a .sh script, but there are times when I have to run two commands sequentially, or I want to test a small part of a bash script but test it from the command line.
sleep 21000 ; killall rsync
I did find that this way works (putting a backslash at the end of the line and putting line 2 at the > prompt):
line 1:
# sleep 21000 ; \
line 2:
> echo command completed
line 3:
> killall rsync
OneCD
Re: Bash Script
Post by OneCD »
Unclear: why are you asking this on a NAS forum? This is basic BASH, and has no relevance to QNAP. :'
nintendo1889
Re: Bash Script
OneCD wrote: Sun May 09, 2021 2:30 am Unclear: why are you asking this on a NAS forum? This is basic BASH, and has no relevance to QNAP. :'
because basic linux functions, such as this, don't work.
https://www.howtogeek.com/269509/how-to ... ss%20Enter.
OneCD
Re: Bash Script
Post by OneCD »
Works fine here. Please ask about this on a Linux forum instead.
* topic locked *
Locked
Return to “Users' Corner”
