I have a TS677 and a TS432.
I love them both, but primarily the 677 and primarily use my TS677 as a large volume media server and archive.
I need a way to quickly and easily generate folder lists; or folder lists and file lists; ; ideally some sort of txt delimited or CSV file. I know this can be done via scripting, but given how tightly I have locked down my units that's a pain to for me to have to do every time I want to generate a list..
I am hoping for a feature in one of the apps to do this, but in the meantime if anyone has a script or workaround to share it would be greatly appreciated.
Simple folder list generator
Re: Simple folder list generator
if you have the share in question mounted on windows .. just open a command prompt, navigate to the folder and do
or
dir /B /S > Listed_Folders.txt
dir /A:D /B >Listed_Folders_and_Files.txt
Thanks; I have done that and used other methods to generate a list from within a client - but I was hoping to find a way to do it quick and easy on the NAS.
With how many files people generally store on a NAS, I think it would be a useful feature to have it as a right click context option in QFile or something like that: "Export File List." etc.
you can do it on the NAS as well, just in linux terms
Navigate to the share in question and do
there is probably many more flags you can use..
The community can not add anything to QNAP apps (e.g. file station) and QNAP does not come here ..
ls -d > directory_names.txt
ls -r > directories_and filenames.txt
- Moogle Stiltzkin
or if ur a windows user like me u can run an app that generates these types of lists
https://www.raymond.cc/blog/print-all-f ... r-printer/
NAS
Network
Resources
Network
Resources
