Lifespan of Qnap devices
I purchased QNAP TVS-671 i3 6 Bay NAS in 2016. It's now running with all 6 disks. Since 2020, it has been running very slow, in the sense that even opening the AppCenter app takes up to a min ( I don't run too many apps too ). I wrote several tickets and most of them were closed with some unacceptable answers.
In the last ticket I wrote, I was told that the NAS is in good shape except that it's aged.
My NAS has 16G ram and it runs on a 4th gen i3 processor. I know the Gen is old, but my Synology is running super smooth and is just running on Intel Celeron J4125.
I am really trying to understand the answer given by the Support team.
It's Qnap that created newer firmware, asked me to upgrade to the latest firmwares, made apps that run slower on the older version.
Is a NAS supposed to live for just 4+ years? then it's worth the $1300 price tag?
Who made my NAS old?
- OneCD
Re: Lifespan of Qnap devices
Up-to 1 minute to open the App Center doesn't sound right. I have QNAP NAS from 2010-2011 that opens App Center in under 10 seconds. Something is slowing your NAS down.
Maybe it's trying to do too-much? What are your system load averages? You can find these by SSH'ing into your NAS as the 'admin' user and running:
uptime
- OneCD
It displays uptime and other things …
It’s also easier to read than ‘top’.
huh..I should give that a try
*tries*
displays uptime and load average ...ok
*tries*
Sure. Please see the attachment. I tried to open AppCenter while monitoring top updates. I saw a few process like notify_thread, birdnestd, kworker, hal_daemon, manaRequest.cgi were mostly showing up into..
<<Removed Attachment>> and added back in the second post from this one.
best to take this down..the top output contains your email address..
post it once in code tags and censor your email out
I missed it. Thanks for letting me know. Will upload again. Thanks!
New Attachment
Btw, am not running any containers but I guess Qnap runs many apps as containers.
- OneCD
Your system loads are a little high. The 15 minute average seems to be hovering somewhere around 5.0. For your dual-core (+HT) CPU, you would generally like it to be no-higher than 4.0 (although, the 2 x hyperthreads are not "real" cores, so 3.0 would be better).
What QPKGs are installed? This command will generate a list of them:
grep '^\[\|^Enable' /etc/config/qpkg.conf
Additionally, what are the make, model and capacity of your HDDs?
Nas has direct access to internet?
Some malware might be running.
Sent from my RMX1931 using Tapatalk
Considering I bought my TS-453Be a little over 3 years ago and now it's dead as a doornail, if you get 4 years+ on one of these units looks like you are doing well.
Remember that the underlying cause is a design weakness in the specific Intel CPU that causes it to degrade over time.Considering I bought my TS-453Be a little over 3 years ago and now it's dead as a doornail, if you get 4 years+ on one of these units looks like you are doing well.
It's not just QNAP devices that have suffered from this same failure mode with this CPU.
Alistair, it's possible the fault with my unit is something different entirely though since the 100 ohm fix made no difference to the status though ? Could be some other underlying fault with the mainboard I guess.AlastairStevenson wrote: ↑Tue Sep 28, 2021 3:55 pmRemember that the underlying cause is a design weakness in the specific Intel CPU that causes it to degrade over time.Considering I bought my TS-453Be a little over 3 years ago and now it's dead as a doornail, if you get 4 years+ on one of these units looks like you are doing well.
