QTS 4.3.6.1154 build 20191212
Download links:
https://download.qnap.com
/Storage/HS-251/HS-251_20191212-4.3.6.1154.zip
/Storage/IS-400/IS-400_20191212-4.3.6.1154.zip
/Storage/SS-1279U/SS-1279U_20191212-4.3.6.1154.zip
/Storage/SS-1879U/SS-1879U_20191212-4.3.6.1154.zip
/Storage/SS-2479U/SS-2479U_20191212-4.3.6.1154.zip
/Storage/TS-1079/TS-1079_20191212-4.3.6.1154.zip
/Storage/TS-1270U/TS-1270U_20191212-4.3.6.1154.zip
/Storage/TS-1279U/TS-1279U_20191212-4.3.6.1154.zip
/Storage/TS-1679U/TS-1679U_20191212-4.3.6.1154.zip
/Storage/TS-470/TS-470_20191212-4.3.6.1154.zip
/Storage/TS-470U/TS-470U_20191212-4.3.6.1154.zip
/Storage/TS-670/TS-670_20191212-4.3.6.1154.zip
/Storage/TS-870/TS-870_20191212-4.3.6.1154.zip
/Storage/TS-870U/TS-870U_20191212-4.3.6.1154.zip
/Storage/TS-879/TS-879_20191212-4.3.6.1154.zip
/Storage/TS-879U/TS-879U_20191212-4.3.6.1154.zip
/Storage/TS-X28/TS-X28_20191212-4.3.6.1154.zip
/Storage/TS-X31/TS-X31_20191212-4.3.6.1154.zip
/Storage/TS-X31U/TS-X31U_20191212-4.3.6.1154.zip
/Storage/TS-X51/TS-X51_20191212-4.3.6.1154.zip
Release note:
[Important Notes]
- To ensure system functionality, after updating QTS to 4.3.6, please also update Container Station to 1.9 in App Center before enabling QVR Pro.
- The RADVD service previously did not have an outgoing interface. Please reconfigure the RADVD service after upgrading.
- Due to security concerns, support for "Wi-Fi ad-hoc mode" has been removed.
- This QTS update changes the file system of the system partition to ext4 for ARM-based models with Annapurna Labs processors. For data security reasons, you are not able to downgrade QTS to a previous version after this update.
Affected models: TS-131P, TS-231P, TS-431P, TS-531P, TS-231+, TS-431+, TS-231P2, TS-431P2, TS-431X, TS-431X2, TS-531X, TS-831X, TS-1231XU-RP, TS-1231XU, TS-831XU-RP, TS-831XU, TS-431XU-RP, TS-431XU, TS-431XeU, and TS-1635.
- For the status of QTS updates and maintenance for your NAS model, visit https://www.qnap.com/en/product/eol.php
- When QTS 4.3.x is installed on NAS models running on 64-bit Intel and AMD processors, some applications may not be supported. To check if installed apps on your NAS are compatible with QTS 4.3.x, download the QTS 64-bit compatibility tool and install it on your current QTS build. (https://download.qnap.com/QPKG/CF64_0.1-1114.qpkg.zip)
- Below are the kernel versions for NAS models that are supported by QTS 4.3.6:
Kernel 3.10.20: TS-128, TS-228
Kernel 3.2.26: TS-x31, TS-x31U
Kernel 3.4.6: TS-x69, TS-x69U, TS-x69L
Kernel 4.2.8: all other models supported by QTS 4.3.6
- Due to the limitations of future kernel updates, QTS 4.3.6 is the final available QTS update for the following NAS models: TS-EC1679U-SAS-RP, TS-EC1679U-RP, TS-1679U-RP, TS-EC1279U-SAS-RP, TS-EC1279U-RP, TS-1279U-RP, TS-1079 Pro, TS-EC879U-RP, TS-879U-RP, TS-1270U-RP, TS-870U-RP, TS-470U-RP, TS-470U-SP, TS-879 Pro, TVS-870, TS-870 Pro, TS-870, TVS-670, TS-670 Pro, TS-670, TVS-470, TS-470 Pro, and TS-470.
- Due to the limitations of non-expandable memory capacity and 32-bit processor architecture, starting from QTS 4.3.6, the TS-128 and TS-228 no longer support Container Station and all the dependent applications, including Notes Station 3, Qcontactz, QcalAgent, AWS Greengrass, and QIoT Suite Lite.
[Fixed Issues]
- Fixed a vulnerability in File Station concerning improper link resolution (CVE-2019-7183).
- A slight delay would occur between the snapshot scheduled time and the actual snapshot taken time.
[Known Issues]
- When a TR-002 external RAID enclosure is connected to a USB 3.1 Gen2 port on the NAS, the bus type incorrectly appears as USB 3.0 in the QTS UI. This is a UI problem only, data will actually be transferred at USB 3.1 Gen2 speeds.
- When data is being transferred to or from a QNAP external RAID enclosure, changes to the status of a degraded RAID group might not be visible immediately in Storage & Snapshots.
- When an external RAID group is in degraded mode its read/write performance will be greatly reduced.
- A failed external RAID group may have the status "Unknown" instead of "Failed".
Welcome note and must-know for QNAP Forum members.
Jump to
- QNAP General
- ↳ Announcements
- ↳ Features Wanted
- ↳ Users' Corner
- ↳ Official Apps
- ↳ Prestashop
- ↳ Webalizer
- ↳ Virtualization Station
- ↳ Notes Station
- ↳ SocialLink Station
- ↳ McAfee Antivirus
- ↳ IT Management Station
- ↳ Container Station
- ↳ Qsirch & Qfiling
- ↳ Community Apps
- ↳ Apps Wanted
- ↳ Partner Apps
- ↳ BitTorrent Sync
- ↳ EZPhone
- ↳ Plex Media Server
- ↳ Ragic
- ↳ Tonido
- Getting Started
- ↳ Frequently Asked Questions
- ↳ Presales
- ↳ Turbo Station Installation & Setup
- General
- ↳ Hardware & Software Compatibility
- ↳ HDD Spin Down (HDD Standby)
- ↳ Seagate Drive Discussion
- ↳ Western Digital Drive Discussion
- ↳ File Sharing
- ↳ Mac OS
- ↳ Linux & Unix (NFS)
- ↳ Windows
- ↳ Backup & Restore
- ↳ Symform
- ↳ Microsoft Azure
- ↳ OpenStack Swift
- ↳ Amazon Glacier
- ↳ Amazon S3
- ↳ WebDAV-based Backup
- ↳ Google Cloud Storage
- ↳ Object Storage Server
- ↳ ElephantDrive
- ↳ Xopero
- ↳ System & Disk Volume Management
- ↳ Web Server & Applications (Apache + PHP + MySQL / SQLite)
- ↳ Download Station and QGet
- ↳ myQNAPcloud service
- ↳ Surveillance Solution
- ↳ Miscellaneous
- ↳ QIoT
- ↳ QuAI
- ↳ QVR Face
- Business
- ↳ Windows Domain & Active Directory
- ↳ iSCSI – Target & Virtual Disk
- ↳ Remote Replication/ Disaster Recovery
- ↳ Server Virtualization & Clustering
- ↳ NAS Management
- ↳ QES Operating System (QNAP Enterprise Storage OS)
- Multimedia
- ↳ Photo Station, Music Station, Video Station
- ↳ Media Streaming
- ↳ Mobile Devices
