Anti Virus Options?
Anti Virus Options?
Is McAffe the only option for AV on a QNAP NAS?
I personally dislike McAffe from long ago issues. I have used Avast for years now and have never been disappointed in it. I asked about Avast on a QNAP NAS over on the Avast forum, but did not receive any useful information.
Re: Anti Virus Options?
mainly virus scans should be done on the clients...and the two available scanners only scan the user data and do not protect the nas itself
No, you also have ClamAV that's best known for it's many false positives and failing signature updates. I wouldn't recommend it!RonRock wrote:Is McAffe the only option for AV on a QNAP NAS?
- Moogle Stiltzkin
i do this tooCylonCenturion wrote:I use NOD32 to scan the NAS ( over the network )
https://www.av-test.org/en/antivirus/home-windows/
NAS
Network
Resources
Network
Resources
- Toxic17
The OP asks for AV alternatives on the NAS.narth wrote:I'v been using $BitDefender for 3 years now. It seems to catch most of the viruses. Have not had any issues.
RonRock, you have ClamAV which is built into the firmware and set as default, OR McAfee. I use both of different NAS's my Main NAS TVS-463 uses McAfee, my Backup NAS uses ClamAV.
Regards Simon
Qnap Downloads
MyQNap.Org Repository
Qnap Downloads
No use arguing with a SEO spambot (or possible referral Spam) .. could you take that spam link out of the quote too ?Toxic17 wrote:
- Toxic17
yep done
Regards Simon
Qnap Downloads
Qnap Downloads
I have the same issue and the same question. Did you find an acceptable solution?RonRock wrote:Is McAffe the only option for AV on a QNAP NAS?
Dan
TVS-473-8GB
QTS Version 4.3.4.0695 Build 2018/08/30
Storage Pool 1 - HDD Volume1 - Four WD Red 4TB in RAID 6 - Thick-Provisioned
NAS backup to WD Red 8TB via USB Dock
CyberPower CP1000PFCLCD
Gigabit home network
TVS-473-8GB
install AV on the client of your choice .. don't bog your NAS CPU with those tasks
Of course. My NAS is the client in this case. That's why I need a suitable AV solution for the NAS itself.dolbyman wrote:install AV on the client of your choice .. don't bog your NAS CPU with those tasks
Dan
TVS-473-8GB
TVS-473-8GB
your NAS is the client ? please elaborate (unless you mean VM)
I have a monitor, mouse, and keyboard connected directly to the NAS. The NAS is connected to the internet. I use it (sometimes) just like a PC. I need protection from all the scary stuff.
Dan
TVS-473-8GB
TVS-473-8GB
As already answered in the thread, the only alternative that run directly in the NAS is ClamAV. Many have tried to use it and almost all of us have given up on it.flagator wrote:I have the same issue and the same question.
For those that are fans of Avast (or any other AV solution) and have a capable NAS, you could have the AV of your choice running in a VM in Virtualization Station on the NAS.
HD station is running in a Linux chroot .. not the same a a windows machine ... also the Virus scanners on the NAS are for the DATA not the OS of the nas
