Hi, I can not connect a network folder (the folder is connected, but it shows an incorrect disk volume or several megabytes). I use one disk Seagete ST3000VX000.
I inserted the disk into a new device - initialized and configured the device.
Start working with TS-219P II (configuration)
Re: Start working with TS-219P II (configuration)
unclear what the issue is...can you explain it again? (screenshots show no error)
