I’d like to ask you for a help in one of the configuration element of my qbittorrent app.
Used AppCenter i installed qbittorrent (4.1.1.0)
In options i set up some parameters, but i have problem how to find place where qbittorrent stores downloaded files.
By default it’s: /share/CACHEDEV1_DATA/.qpkg/QBittorrent4/Downloads/
I didn’t change this patch, and put some files to download. Files was downloaded, and then I’d like to move those files to windows. And I found out problem: I can not find those files on my qnap disks…
I tried serch those files by name in file station with no results.
Unfortunatelly I’m not fluent in linux so I don’t know how to interprete even default path (I mean where it is on qnap HDD’s).
I’d be glad if you can help me in this topic.
I have QNAP TS-453A and fw 4.3.4 (20180710)
Regards
qbittorrent question
Re: qbittorrent question
I save the files in /share/homes/admin/Movies/ which is visible from Windows.
You can connect to your NAS using ssh command.
I had the same problem and I did the following:
ssh <user>@<qnap.private.ip> (where user is admin in my case)
cd /share/CACHEDEV1_DATA/.qpkg/QBittorrent4/Downloads/
mv Her\ \[MicroHD\]\[1080\ px\]\[DTS\ 5.1-AC3\ 5.1-Castellano-AC3\ 5.1\ Ingles+Subs\]\[ES-EN\]/ /share/homes/admin/Movies/
I hope it helps.
I hope it helps.
Thanks @deldie for your help.
What i missed in the config was the word "share" just after "/"
Now it works perfectly
regards
regards
Hi guys, need some help here.
I dont really understand the commands and stuff. Can i just set it to one of my folders in my qnap file station?
Even I have the same problem . I am not quite familiar with the SSH commands . Is there a way i can use the GUI to browse to my qbittorrent download folder and take the files out.
My current Path is /share/CACHEDEV1_DATA/.qpkg/QBittorrent/Downloads/
I want to change it to The Main download folder
Did u get an answer?mathannath wrote: ↑Tue Oct 08, 2019 10:31 pm Even I have the same problem . I am not quite familiar with the SSH commands . Is there a way i can use the GUI to browse to my qbittorrent download folder and take the files out.
I got a solution, download a app called "electerm", and connect to the NAS via SSH, the app provide a visible way to move and copy the folder, and no need to using the complicated SSH commandmathannath wrote: ↑Tue Oct 08, 2019 10:31 pm Even I have the same problem . I am not quite familiar with the SSH commands . Is there a way i can use the GUI to browse to my qbittorrent download folder and take the files out.
- OneCD
