QWA-AC2600: Clients no Internet connection
Hello everyone,
this is about the following adapter: https://www.qnap.com/en/product/qwa-ac2600
Setup: The 2.4Ghz band is used to connect to the router for Internet access, the 5Ghz band is used as an access point via WirelessAP. The NAS has an Internet connection and a client can also connect to the access point. However, the Internet connection is not passed on to the clients. How can I change this?
Re: QWA-AC2600: Clients no Internet connection
dont think anyone here uses wifi adapter on the qnap .. horrible idea
if you need wifi access, let the router handle it
Are all of your 10k posts that counterproductive? I´m asking for help and input and this is what you´ve got?dolbyman wrote:dont think anyone here uses wifi adapter on the qnap .. horrible idea
Back to topic: Anyone knows how to setup the virtual switch?
gist of it was .. best to ask qnap .. they pushed out those products .. hardly anyone uses them
so your best bet in terms of support is QNAP helpdesk
https://helpdesk.qnap.com/
But if any other user wants to take a shot at this config .. go ahead
- spikemixture
- Been there, done that
@ derlordis0n
I too wish to know how this works as mine is arriving in 7 days
I assumed you d/l the new app " WirelessAP Station "
The way I read this card (and briefly watching the qnap videos here http://tinyurl.com/ydxntbjs the purpose is an access point to take a load off your router.
I have about 25 wireless clients (and 30 hardwired) connected now so to relieve some of that can't be a bad thing.
When mine arrives I will watch the setup part again of the video...
Qnap TS-1277 1700 (48gb RAM) 8x10TB WD White,- Raid5, 2x M.2 Crucial 1TB (Raid 1 VM),
2x SSD 860 EVO 500gb (Raid1 QTS), 2x SSD 860 EVO 250GB (Cache), 2x M.2 PCIe 970 500gb NVME (Raid1 Plex and Emby server)
GTX 1050 TI
Qnap TVS-1282 i7 (32GB RAM) 6x8TB WD White - JBOD, 2x M.2 Crucial 500gb (Raid1 VM),
2x SSD EVO 500gb (Raid1 QTS), 2x SSD EVO 250gb (Raid1 Cache), 2x M.2 PCIe Intel 512GB NVME (Raid1-Servers)
Synology -1817+ - DOA
Drobo 5n - 5x4TB Seagate, - Drobo Raid = 15TB
ProBox 8 Bay USB3 - 49TB mixed drives - JBOD
All software is updated asap.
I give my opinion from my experience i.e. I have (or had) that piece of equipment/software and used it!
GTX 1050 TI
Hi Spikemixture,
any success? Support hasn´t getting back to me in 2 weeks (!).
Cheers
Cheers
- spikemixture
derlordis0n wrote:Hi Spikemixture,
Cheers
I have been harassing Qnap about my unit - It has not been sent yet!
GTX 1050 TI
GTX 1050 TI
- Moogle Stiltzkin
not trolling, but could you please elaborate ?dolbyman wrote:dont think anyone here uses wifi adapter on the qnap .. horrible idea
if wireless access to the qnap is required, then why isn't direct wireless to the qnap instead of router better?
according to the marketing people, they said the point of doing it instead of router was to offload wireless from router, and instead go direct to the qnap instead.
other than that, just providing a wireless ap to the qnap, if a wired setup is not possible for the user (maybe they could resort to a wireless router or ethernet homeplug instead alternatively > )
actually i got emails. one was confirmation i won. the 2nd part was about shipping received and being shipped out. i'm wondering if you got the 2nd part>spikemixture wrote:derlordis0n wrote:Hi Spikemixture,
Cheers
i'd love to help but not sure i have an answer to this.derlordis0n wrote: Are all of your 10k posts that counterproductive? I´m asking for help and input and this is what you´ve got?
my own setup.... i configured virtual switch 1 for use for ethernet1 wired. also for PIA VPN (which also serves as gateway, meaning ip of the QNAP is based on the VPN client in QVPN i setup).
then wireless adapter uses virtual switch 2. I tried both ap station, and without. with ap station it sets the qnap as an AP for stuff to connect to. the other method you connect to another AP. so i'm using the later, simply because my setup connects wirelessly through the router, to the QNAP (which is also wireless). simply because my client pc wireless ** compared to my router. And my pc is wired to router. so the only thing wireless is between the router and the qnap
for internet connectivity, it seemed to work since cloudlink was working also vpn works.
NAS
Network
Resources
Network
Resources
@moogle ..why offload witeless from the router? .. that thing was made for it ...wifi on the qnap is just an added feature like karaoke,machine learning or iot ....
if nas core features were all flawless ..fine ..but qnap struggles to keep even those running
- Moogle Stiltzkin
[youtube=]hKLfqRRPY3c[/youtube]
their explanation is @ 5:55
NAS
Network
Resources
Network
Resources
I looked at the video part.. still dont think there is any advantage
a dedicated ap would mean a sepperate ssid you would need to connect to .. or as in bridge mode mode ... then why not use a dedicated bridge that can run without the nas ?
anyways .. I still keep my NAS and wifi sepperate ...
hope that function does not get dropped in a couple of firmware versions to turn those cards into paperweights (for the sake of customers that bought it)
but look at the upside here moogle (for other forum users)...you are a regular user that has this card (albeit won in a contest) .. so you will be the goto "support person" from now on :p
before I always said ..no forum regular has such a card ..so support will be limited
- Moogle Stiltzkin
you mean like this?
[youtube=]ztAk_58oXLk[/youtube]
from what i saw it could setup the qnap using ap station (yes you setup a ssid for other things to connect to it) or the other method which is connect direct from the wireless adapter to other available access points (e.g. the router). the later sounds exactly like the setup you are suggesting?
so it's a buy either the wireless adapter, or a second router question then i suppose. with the adapter you don't have require an ac adapter (since it's powered internally), but with a router you do
the only third party reviews i found were these
but yes if it's something i know since i tried and tinkered with the settings available, i will speak up though to assist where possible ...as usual...
[youtube=]0PMb-WNgrQ4[/youtube]
[youtube=]y8Ab8c7e_K0[/youtube]
i use very basic setups.... and i'm not an expert on subject matter. i'd prefer to refer them to helpdesk when possible ^^;dolbyman wrote: but look at the upside here moogle (for other forum users)...you are a regular user that has this card (albeit won in a contest) .. so you will be the goto "support person" from now on :p
NAS
Network
Resources
Network
Resources
