Hello!
I have a TS-231P Nas with 4.3.6.0993 build 20190704 firmware.
Unfortunately from some weeks, I am experiencing sudden and unwanted shutdown. I am in contact with the tech support also, but until now no solutions at the horizon .
Today, a new sudded and untriggered shutdown has happened. But this time, I heard the shutdown warning beep and I immediately connected to the NAS via web interface. I saw a window with the line 'failed update' with the reference to a log file. Unfortunately the NAS had turned off few second later and I do not remember the log file name and path.
In Control Panel >Sys Log there are no errors, and the shudown log message that you can read in Sys Log is like a normal shutdown without any reference to the process that has triggered it. Even the tech support says that shutdown is voluntary.
Do you have any idea where I can find the log file referenced in the windows that I saw? I think that this file is very important to understand which process is triggering the shutdown and solve the problem.
QNAP Sudden and Unwanted Shutdown
- Toxic17
Re: QNAP Sudden and Unwanted Shutdown
these can be quite hard to diagnose. firstly I would would ask have you changed/swapped out memory modules from the default QNAP ram that is fitted as time of purchase.
is your Power supply 110-115v/230-240v supply ok? do you use surge protection or UPS?
might be worth running the QNAP Diagnostics tool (QPKG) and see if that finds anything from all the system log files. did you submit these log files to QNAP support?
Regards Simon
Qnap Downloads
MyQNap.Org Repository
Qnap Downloads
Yes I sent all my dumps and log file to tech support. They suggested me to try installing manually the firmware, however the NAS keeps to restart randomly. Eventually I solved the problem by reinitializing the NAS. I hope that this post can help other users that may experienced my same problem.
Unfortunately I was totally wrong because the NAS reinizialization did not solve the problem. Last night I was able to take a screenshot from the QTS web interface just few second before the NAS was shut down automatically. Here is the screenshot:
https://ibb.co/yfmJfkR
My questions are:
- Why on earth the NAS for a failed update (not wanted) should shutdown AUTOMATICALLY making itself useless?
- How can I inspect the system registry as indicated in the message?
- How can I solve the problem? I am experiencing sudden and unwanted shut down since March 2019 and even the tech support that I contacted seems able to solve the problem!
My questions are:
- Toxic17
I suggest you try updating the firmware manually using this method below.
if it fails you should see some output of why.
https://wiki.qnap.com/wiki/Manually_Updating_Firmware
Regards Simon
Qnap Downloads
Qnap Downloads
- Moogle Stiltzkin
is yours a random reboot? it will constantly reboot on it's own?
or does it just shutdown and not power backup?
doubt this is related, but i posted other random reboot issues if you want as reference, based on other possible causes
viewtopic.php?f=142&t=150707
NAS
Network
Resources
Network
Resources
It shouldn't.
"...registri di sistema." translates to the System Logs to me but you already checked that and obviously Qnap suspport did as well.- How can I inspect the system registry as indicated in the message?
It's not a solution but it could be a workaround to try, untick the automatic firmware check and do your firmware updates manually.- How can I solve the problem? I am experiencing sudden and unwanted shut down since March 2019 and even the tech support that I contacted seems able to solve the problem!
- storageman
Does it poweroff when the disks are not installed?
Are the disks compatible?
Any non-Qnap RAM?
Any non-Qnap RAM?
In the past I tried a manual update. The NAS updated successfully but the problem is still present.
The NAS power off when the disk are installed.storageman wrote: ↑Thu Sep 26, 2019 4:12 pm Does it poweroff when the disks are not installed?
Any non-Qnap RAM?
I have an HSGT 4T Nas drive.
I have only Qnap RAM.
The NAS shuts down and does not power on automatically. I have to press the power button manually to make the NAS working again. This is the reason why this problem is super annoying expecially if you need to access the NAS remotely.Moogle Stiltzkin wrote: ↑Thu Sep 26, 2019 9:02 am is yours a random reboot? it will constantly reboot on it's own?
I think this is a reasonable temporary solutions. However tomorrow the Qnap developers will inspect the NAS with a remote session and I hope they will find the solution.
Australian QNAP owner here. No problems whatsoever with my TS-231P for the past 3ish years until 4 days ago when I moved ISP.,
edit2: Nup, think it is just heat related, if I use the auto-fan option, it will shut down reasonably quickly, within a day or 2, even at 20degC ambient (the CPU/board is about 36degC, the HDDs 47degC). If I choose the option to have max fan after 45 and min fan below 35, it seems it stays up for weeks, but I guess an antivirus scan or some other process is working the heat up sometimes and it still (gracefully) shuts down. I use Surveillance station & camera record also, but only when it sees motion events, this seems to build up the HDD heat at times also.
