I rebooted my TS-879Pro because it wasn't answering on the SMB service and the web interface was being slow and displaying weirdly. After the reboot, it's better but I notice that a bunch of services are running that I don't think I had started (PLEX server etc.). I've quit most of these apps, but there are a few that won't quit because when I click the down arrow next to the "Open" dropdown menu, either nothing happens, or it only shows the Display On option:
Nothing happens: Cloud backup sync, QTS SSL certificate
Display On is the only option: License Center, Resource Monitor, Network and Virtual Switch
what's going on, why can't I quit these things (and how do I find out why all of them were running all of a sudden)?
Can't quit some apps??
TS-879Pro (firmware 4.2.0, 8 hard drives in a RAID6, accessed from Apple machines)
Re: Can't quit some apps??
At least most of the services that you list are vital for your NAS working and intended to run.
I wouldn't expect Plex unless being installed though.
Compared to me you have about twice as many apps installed. Do you really need that when you apparently is allergic to having any of them running?
I guess that's the question. Of the apps that I showed running, which are necessary to the NAS? I don't seem to remember them being on before. But whichever ones aren't required, I'd like to turn them off. I can delete other apps no problem, but they aren't running so are not bothering anything. The only reason I'm even worried about any of them is that the NAS has gotten slower when serving files through SMB, and the other day got so bogged down that the GUI wouldn't work well even.
I don't know but that you can't shut an app down sound like a very good indication of that it's necessary.
I doubt that the very few apps you still have running there is causing your problems. I have many more running (but far less installed) and as you can see on the Resource monitor in the left lower corner, my NAS isn't bogged down by it: What does your CPU and RAM usage look like?The only reason I'm even worried about any of them is that the NAS has gotten slower when serving files through SMB, and the other day got so bogged down that the GUI wouldn't work well even.
What does the System log tell you?
Is the NAS reachable from the internet, if so what services?
I can't find Malware Remover among your apps and that's an app that I'd recommend to have running.
%top give right nows:
CPU: 1.8% usr 0.8% sys 0.1% nic 96.4% idle 0.6% io 0.0% irq 0.0% sirq
Load average: 1.20 1.24 1.17 2/926 29116
is there something through the web GUI that is more informative?
the only thing I see is repeated lines of
Severity Level Date Time Users Source IP Application Category Content
Warning 2019/08/09 08:33:05 System 127.0.0.1 --- --- Re-start process nvrd due to live report out-of-date
which I'd love to get rid of, but haven't figured out a way. Also I'm not sure it's showing me everything (even though it's set to show all) because for example I don't see the reboot event.
yes. At the time the problem happened, it was reachable but acting very slow and wonky, both over http and SMB. Over the last month I've noticed that SMB has been slower than before (video files viewed by VLC over SMB connection pause sometimes). Right now it seems to be ok via ssh and http;
ah! I'll install; I didn't know we needed that on Linux too. Is that something I run periodically, or leave it running all the time?
I'm no expert with top but it look like your system isn't overloaded, though still far from idle.
I don't know but I'd guess that nvrd is related to Surveillance Station. You have both Surveillance station and QUSBCam installed and maybe they didn't shut down properly when you disabled the apps?> What does the System log tell you?
I'm not sure you understood what I meant so I have to ask again. Is your NAS really open and available from anywhere on the whole internet over http and CIFS/SMB? Or are you talking about only on your local LAN?> Is the NAS reachable from the internet, if so what services?
All operating system can be hacked and NASes are attractive targets for the bad guys.> I can't find Malware Remover among your apps and that's an app that I'd recommend to have running.
Malware Remover will automatically scan the system as long as you have it running.
sorry, I didn't understand. No, it's behind a cablemodem and a router, and should not be available to anyone not on the LAN.
yes; posts on-line suggest it's a bug and I haven't seen anyone find a solution other than to not run the Surveillance Station.
